profile an application on tx2 using Nsight on a host pc
I tried to profile an application on tx2 (video processing through ROS) using Nsight on a host pc. Nsight managed to connect to the target and run the application successfully, but after the app is done the timeline stays empty… I did a screen recording to see if i missed anything.
Thank you
Please noticed that our profiler requires root authority from CUDA v10.0.
Have you login Nsight as root?
Already tried root on host and target, no change.
Please advise
Thanks, Yoni
May I know the link of your screen recording.
This will help us to know if there is anything missing.
Please see the link:
Thank you
Sorry for the late reply.
Please noticed that the profiling data is output as file after the the process finished.
Not sure if the stop button will cause any abnormal exit or not.
Would you mind to use the “Execution timeout” instead?
Thanks and please let us know the result.
