If I write a simple C file ‘test.c’ below and then generate a binary ‘test.out’
#include<stdio.h>
int main(){
printf("%s\n", "test");
return 0;
use this command to profile:
nsys profile ./test.out
It has no such runtime_error and runs successfully:
Importing the qdstrm file using /opt/nvidia/nsight-systems/2019.4.2/host-linux-x64/QdstrmImporter.
Importing...
Importing [==================================================100%]
Saving report to file "/home/edge/Workspace/nsys/report1.qdrep"
Report file saved.
Please discard the qdstrm file and use the qdrep file instead.
Removed /home/edge/Workspace/nsys/report1.qdstrm as it was successfully imported.
Please use the qdrep file instead.
What version of Nsight Systems are you using? You can determine the version of nsys you are using with the “nsys --version” command.
I used the latest version, “NVIDIA Nsight Systems version 2019.6.1.101-8582829”, shipped in mid-December and available at Gameworks Download Center | NVIDIA Developer. With the latest version, I could not reproduce your issue using the test.py script you provided.
The command line you provided, “nsys profile --trace=cuda,cudnn,cublas,osrt,nvtx --delay=60 python my_dnn_script.py”, looks fine. It should work.
my config:
Driver Version: 440.33.01 CUDA Version: 10.2
(those marked as gconfig below)
In my case, IronRoyGrey’s test.c report the same problem.
And I even can not reproduce this problem in another machine with the same OS, gconfig and GPUs.
