Profile multiple kernels, once each
I’m using ncu, and I’d like to profile multiple kernels. I know I can do that with the --kernel-name flag and regex, e.g.,
--kernel-name regex:"volta_scudnn_128x32_3dconv_wgrad_xregs_large_nn_v1|volta_scudnn_128x32_3dconv_fprop_small_nn_v1|bn_fw_tr_1C11_kernel_NCHW|bn_bw_1C11_kernel_new|volta_scudnn_128x64_3dconv_fprop_xregs_large_nn_v1"
The problem is if I use -c 1 to only profile once then that applies to all kernels - so whichever one of those five is launched first gets profiled. I can use -c 5, but then if a kernel gets launched multiple times before another kernel in the list I’ll still miss profiling one.
Can I specify multiple kernel names, and have each name profiled once?
Hi, @user22230
Thanks for using Nsight Compute.
Regarding your request, the recommendation is to use --kernel-id
Details can refer Training — NsightCompute 12.4 documentation
This has the same problem as --kernel-name: I can specify multiple kernels with regex but the -c argument applies to all of them as a group, not individually.
Hi @user22230
Please confirm if you used –kernel-id option instead of --kernel-name option like below,
–kernel-id :: regex:"volta_scudnn_128x32_3dconv_wgrad_xregs_large_nn_v1|volta_scudnn_128x32_3dconv_fprop_small_nn_v1|bn_fw_tr_1C11_kernel_NCHW|bn_bw_1C11_kernel_new|volta_scudnn_128x64_3dconv_fprop_xregs_large_nn_v1":1
If you are willing to profile all first instances of kernels matching with provided regex then do not use -c option along with it.
-c will limit the total number of profiled kernel launches. For example if you provide -c 3 with above option then NCU will profile 3 kernels in total which will match above --kernel-id filter.
You can refer profile filter options here 4. Nsight Compute CLI — NsightCompute 12.4 documentation
I hope this will help you out.
Thanks, that gets closer. I get this output now, using the option --kernel-id ::regex:"gemv2N_kernel|dgrad_engine|dgrad2d_alg1_1":1 (different kernels than original post):
==PROF== Profiling “1:13:gemv2N_kernel:1”: 0%…50%…100% - 1 pass
==PROF== Profiling “1:14:gemv2N_kernel:1”: 0%…50%…100% - 1 pass
==PROF== Profiling “1:7:dgrad_engine:1”: 0%…50%…100% - 1 pass
==PROF== Profiling “1:7:dgrad2d_alg1_1:1”: 0%…50%…100% - 1 pass
==PROF== Profiling “1:25:gemv2N_kernel:1”: 0%…50%…100% - 1 pass
==PROF== Profiling “1:26:gemv2N_kernel:1”: 0%…50%…100% - 1 pass
What is the second number in 1:number:kernel name:1? A couple kernels are profiled twice but this number is different, does that indicate that the kernels are different somehow (despite having the same name)?
Hello @user22230,
Good to see the progress.
It is a stream number. "1:13:gemv2N_kernel:1" is in the same format as the --kernel-id argument’s format context-id:stream-id:kernel-name:invocation-nr
Right, those kernels are different in the sense those are from different streams.
Best Regards.
Perfect, this is what I want. Thanks!
