Forwarding issue from Pytorch: SIGSEGV when using DDP + NCCL + nsys profiling + Pytorch 1.13 · Issue #94393 · pytorch/pytorch · GitHub that seems to be related to nsys + nccl 2.14.3 rather than Pytorch:
import os
import torch
import torch.distributed as dist
import torch.multiprocessing as mp
import torch.nn as nn
import torch.optim as optim
from torch.nn.parallel import DistributedDataParallel as DDP
def setup(rank, world_size):
os.environ['MASTER_ADDR'] = 'localhost'
os.environ['MASTER_PORT'] = '12355'
# initialize the process group
dist.init_process_group("nccl", rank=rank, world_size=world_size)
def cleanup():
dist.destroy_process_group()
class ToyModel(nn.Module):
def __init__(self):
super(ToyModel, self).__init__()
self.net1 = nn.Linear(10, 10)
self.relu = nn.ReLU()
self.net2 = nn.Linear(10, 5)
def forward(self, x):
return self.net2(self.relu(self.net1(x)))
def demo_basic(rank, world_size):
print(f"Running basic DDP example on rank {rank}.")
# create model and move it to GPU with id rank
model = ToyModel().to(rank)
ddp_model = DDP(model, device_ids=[rank])
loss_fn = nn.MSELoss()
optimizer = optim.SGD(ddp_model.parameters(), lr=0.001)
optimizer.zero_grad()
outputs = ddp_model(torch.randn(20, 10))
labels = torch.randn(20, 5).to(rank)
loss_fn(outputs, labels).backward()
optimizer.step()
cleanup()
def run_demo(demo_fn, world_size):
mp.start_processes(demo_fn,
args=(world_size,),
nprocs=world_size,
join=True,
start_method="fork")
if __name__ == "__main__":
run_demo(demo_basic, torch.cuda.device_count())
When running this script with Pytorch 1.13.1+cu117, under nsys profiling only (I’ve been using Nsight Systems 2023.1.1 but it’s also happening with 2022.4.2) ~/.local/share/nsight_systems/nsys profile python test_ddp.py
, I get a SIGSEGV on rank 0.
Here is the GDB backtrace:
#0 0x0000000000000000 in ?? ()
No symbol table info available.
#1 0x00007ff5c8b0f1da in ?? () from /home/juh/.local/share/nsight_systems/libToolsInjection64.so
#2 0x00007ff5c885f606 in NSYS_DL_dlvsym () from /home/juh/.local/share/nsight_systems/libToolsInjection64.so
#3 0x00007ff58be01168 in initOnceFunc () at misc/ibvwrap.cc:94
ibvhandle = 0x7ff518002d30
tmp = <optimized out>
cast = 0x7ff59acdfb08 <ibv_internal_reg_dmabuf_mr>
__func__ = "initOnceFunc"
#4 0x00007ff5c83ae4df in __pthread_once_slow (once_control=0x7ff59acdfba4 <initOnceControl>, init_routine=0x7ff58be00ec0 <initOnceFunc()>) at pthread_once.c:116
_buffer = {__routine = 0x7ff5c83ae530 <clear_once_control>, __arg = 0x7ff59acdfba4 <initOnceControl>, __canceltype = 0, __prev = 0x0}
val = <optimized out>
newval = <optimized out>
#5 0x00007ff5c83ae595 in __GI___pthread_once (once_control=once_control@entry=0x7ff59acdfba4 <initOnceControl>, init_routine=init_routine@entry=0x7ff58be00ec0 <initOnceFunc()>) at pthread_once.c:143
#6 0x00007ff58be01847 in wrap_ibv_symbols () at misc/ibvwrap.cc:139
No locals.
#7 0x00007ff58bde3349 in ncclIbInit (logFunction=<optimized out>) at transport/net_ib.cc:150
shownIbHcaEnv = 0
__func__ = <optimized out>
nIbDevs = <optimized out>
devices = <optimized out>
userIbEnv = <optimized out>
userIfs = <optimized out>
searchNot = <optimized out>
searchExact = <optimized out>
nUserIfs = <optimized out>
d = <optimized out>
context = <optimized out>
nPorts = <optimized out>
devAttr = <optimized out>
port = <optimized out>
portAttr = <optimized out>
res = <optimized out>
line = <optimized out>
addrline = <optimized out>
d = <optimized out>
#8 0x00007ff58bdbb84a in netGetState (state=<synthetic pointer>, i=1) at net.cc:245
ndev = 32757
#9 ncclNetInit (comm=comm@entry=0x555d647315b0) at net.cc:273
state = <optimized out>
i = 1
netName = <optimized out>
ok = false
#10 0x00007ff58bd7e687 in commAlloc (comret=comret@entry=0x555d64123530, ndev=ndev@entry=1, rank=rank@entry=0) at init.cc:323
comm = 0x555d647315b0
__func__ = "commAlloc"
#11 0x00007ff58bd8363e in ncclCommInitRankFunc (job_=<optimized out>) at init.cc:1088
job = <optimized out>
newcomm = 0x555d64123530
nranks = 1
commId = {internal = "\002\000\245\355\254\032-6", '\000' <repeats 119 times>}
myrank = 0
cudaDev = <optimized out>
res = ncclSuccess
__func__ = "ncclCommInitRankFunc"
#12 0x00007ff58bd7bd68 in ncclAsyncJobMain (arg=0x555d29662100) at group.cc:62
job = 0x555d29662100
__func__ = "ncclAsyncJobMain"
#13 0x00007ff5c88b4c0d in ?? () from /home/juh/.local/share/nsight_systems/libToolsInjection64.so
#14 0x00007ff5c83a5609 in start_thread (arg=<optimized out>) at pthread_create.c:477
ret = <optimized out>
pd = <optimized out>
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140691213436672, 2100541623046917983, 140732780327214, 140732780327215, 140732780327216, 140691213434304, -2104046464448442529, -2104008895042138273}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = 0
#15 0x00007ff5c816e133 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
No locals.
The backtrace is leading me to believe there is some kind of incompatibility between this version of nccl and nsys. Unfortunately, this is the nccl version that Pytorch is currently using for its binaries, so it would be very interesting to see if it could be fixed on the nsys side.
