Profiling of Driveworks?
Hello is there a way to do profiling of Driveworks using Nsight?
Our application will use Driveworks, dataconditioner API and dNN along with some custom cuda kernel and post-processing outside of gpu. Consider this to be a monolithic code like the object_tracker_sample that is present as a sample code.
  1. How can I profile DataConditioner’s crop+resize and DNN execution respectively.
  2. How can i profile a general dw_Image_transformation apis?
a. What is the Driveworks API’s that I have to use within my code to get log for Nsight?
Shashank
Dear @shashankg,
Yes. You can profile the DW application using nsys. Did you try and notice any issue?
