i ran into an very strange issue.
When i compile and run my program normaly everthing works fine.
But when I switch to emulation mode the numerical recipies I’m using complain that they cant find the standard c libraries (iostream …).
Im using cmake to configure my project and tested it on 2 different linux systems.
Does anybody have a similar problem or an idea what i could do?
If necessary I can provide further Information about my Program/Configuration.
Would be very thankful if somebody has an idea.
Update:
Here is the error i get in emu mode and like i said in device mode the files are found without a problem
[codebox]In file included from /home/flo/projects/src/myproject/src/mutualInformation.h:12,
from /home/flo/projects/src/myproject/src/mutualInformation.cu:1:
/home/flo/projects/src/myproject/src/Numerics/nr.h:3:19: error: fstream: No such file or directory
/home/flo/projects/src/myproject/src/Numerics/nr.h:4:19: error: complex: No such file or directory
In file included from /home/flo/projects/src/myproject/src/Numerics/nrutil.h:1,
from /home/flo/projects/src/myproject/src/Numerics/nr.h:5,
/home/flo/projects/src/myproject/src/Numerics/nrutil_nr.h:4:18: error: string: No such file or directory
/home/flo/projects/src/myproject/src/Numerics/nrutil_nr.h:5:17: error: cmath: No such file or directory
/home/flo/projects/src/myproject/src/Numerics/nrutil_nr.h:7:20: error: iostream: No such file or directory
CMake Error at my_registration_generated_mutualInformation.cu.o.cmake:147 (message):
make[2]: Leaving directory `/home/flo/projects/build/myproject’
Error generating
make[1]: Leaving directory `/home/flo/projects/build/myproject’
/home/flo/projects/build/myproject/src/./my_registration_generated_mutualInformation.cu.o[/codebox]
