Hello all,
I can’t get the debugger to run my test program. When I try to run it, I get the errors “No protocol specified,” followed by “freeglut (GL): failed to open display ‘:0’.” The program then exits.
As you can tell, I am using freeglut, but I don’t see why that should be a problem.
All environment settings are at their defaults except for PWD, which is set to the folder containing the executable and shaders.
Thanks in advance.
