i am a beginner in programming using CUDA. i have installed CUDA toolkit and sdk and also vs wizard. now when i run a sample program from sdk it gets exit saying cudaOpenMP.exe native exited with code 1(0x1)…
when i ran program using breakpoint in cudaOpenMP program i found it gets exit as soon as it execute the following line:
Are these different on Windows? I don’t see cudaOpenMP with 2.1. Unfortunately I’m running 2.2 beta toolkit so things won’t compile.
in re. “please help me so that i can test the sample and start my project” I suggest you try to start anyway; the code samples aren’t infinitely useful. Check out uiuc’s lectures http://www.nvidia.com/object/cuda_education.html. Try pycuda if you want a slightly easier start.
yes they are the same but it doesnt have all the files… there are 64 such projects in windows… alright so you have matrixMul program… so at line no 108 in matrixMul.cu my program get exit at that line…
pycuda has pretty nice error handling and uses the driver api, so it might work.
I’m getting some compile error “macro “__cudaRegisterEntry” passed 3 arguments, but takes just 2” with both the 2.1 and the 2.2 sdk… it’s possible this is because the 2.2 toolkit is still in beta. Sorry I can’t be more useful.
