Program sleep on J40 pins?
I’m trying to hook my jetson nano up to a relay so i can turn it off and on from a distance.
I found the wake on J40-1 but is it possible to set a falling edge trigger with a shutdown on J40-1 aswell?
Yes, pin 1 of J40 can be used as manually power on/off control.
  1. Short pin 7 & 8 of J40 to disable auto-power-on function.
  2. Then shortly short pin 1 to ground to power on system, or long (~10s) short pin 1 to ground to power off system.
