Programming API documentation for Video Codec SDK 11.1.5
Where do I find API documentation for NVEncode functions at the SDK 11.1.5 level? The programming guide is way too vague and the examples look a bit complicated. All I’m looking for is to convert a set of image buffers in RGB format into a video format supported by this SDK.
Hi @drwootton1 ,
did you check out the Online documentation for the SDK? The programming guide there is explicit and detailed, and admittedly rather technical by necessity.
And looking at the examples in the SDK they are written as simple as possible. If you want an additional level of abstraction (or simplification), are you aware of the Python bindings for NVENC? Have a look at the Video Processing Framework on github.
I hope this helps.
