I’m on ORIN Jetson AGX Developer kit
L4T 35.1.0 [ JetPack 5.0.2 ]
Reading document posted by dusty-nv - jetson-inference/docs/building-repo-2.md
All was successful, until the “Compiling the Project” step.
I executed the $ make command from the jetson-inference/build directory.
Then i see errors during tensorNet.cpp, captureWindow.cpp, and PyNumpy.cpp compile:
…condensed…
[ 49%] Building CXX object CMAKEFiles/jetson-inference.dir/c/tensorNet.cpp.o
…tensorNet.cpp: In member function 'bool tensorNet::LoadNetwork…
…tensorNety.cpp1216:25: warning ‘.calibration’ directive writing 12 bytes into a region of size between 1 and 4096
…tensorNet.cpp:1216:9: note: ‘sprintf’ output between 13 and 4108 bytes into a destination of size 4096
…tensorNet.cpp:1222:25: warning: ‘.engine’ directive writing 7 bytes into a region of size between 1 and 4096
…tensorNet.cpp:1222:9: note: ‘sprintf’ output between 8 and 4103 bytes into a destination of size 4096
[ 75%] Building CXX object tools/camera-capture/CMakeFiles/camera-capture.dir/captureWindow.cpp.o
…jetson-inference/tools/camera-capture/captureWindow.cpp: In member function ‘glWidget* CaptureWindow::GetWidget(int) const’:
…/jetson-inference/tools/camera-capture/captureWindow.cpp:222:1: warning: no return statement in function returning non-void [-Wreturn-type]
[ 91%] Building CXX object utils/python/bindings_python_3.8/CMakeFiles/jetson-utils-python-38.dir/PyNumpy.cpp.o
…/jetson-inference/utils/python/bindings/PyNumpy.cpp: In function ‘PyObject* PyNumpy_ImportNumpy()’:
…/jetson-inference/utils/python/bindings/PyNumpy.cpp:313:1: warning: control reaches end of non-void function…
[100%] Linking CXX shared library …/…/aarch64/lib/python/3.8/jetson_inference_python.so
[100%] Built target jetson-inference-python-38
Did I miss a step? I assume others have had similar issues?
Thanks for the Help!
