I have a project as shared library, referenced by an executable project
I wanted to rename the shared library project (it seemed a proper thing to do at the time), but this was the worst mistake I have made
Whenever I now add the shared library project as reference to the executable project, it would include the old name as well as the new name as part of paths and so forth
Also, when I switch build configurations between debug and release, it would again reintroduce the old name as path and so forth, even if I previously removed it (manually) to be able to build the projects
This of course has undesirable effect when I then build the projects
