Project Omni Guard: Requesting Jetson Orin Nano Developer Kit Allocation for Edge-AI Structural Health System
Hello NVIDIA Community Team,
​My name is Dipesh Kachhi, and I am a high school student based in India developing an independent edge-computing initiative called Project Omni Guard.
​Omni Guard is a proactive, localized Structural Health Monitoring (SHM) telemetry node designed to detect sub-visual mechanical micro-fractures in public infrastructure (bridges, transit framing) before catastrophic structural failure occurs.
​I am reaching out to request a hardware grant or developer kit allocation for an NVIDIA Jetson Orin Nano (8GB). Consumer-grade single-board computers lack the parallel processing architecture and TensorRT acceleration frameworks required to execute the real-time processing demands of this project at the absolute edge.
​1. Technical Architecture & Why Jetson is Mandatory
​The Omni Guard node shifts structural monitoring away from high-latency cloud processing by running a concurrent dual-tier edge computing pipeline:
​Vibration Telemetry Subsystem: The system samples high-frequency data from high-G industrial vibration arrays. The processing core executes continuous real-time Fast Fourier Transforms (FFT) to map the physical harmonic footprint of the structure, identifying internal shifts and joint shears.
​Computer Vision Subsystem: Simultaneously, the node uses vision processing to run localized, edge-optimized object detection models (YOLO variants) across structural surfaces. The system maps surface crack propagation and physical displacement, actively cross-referencing visual degradation with real-time vibration telemetry profiles.
​Running dual MIPI-CSI camera feeds alongside high-frequency sensor ingestion without cloud dependencies requires deterministic, hardware-accelerated computation. The 40 TOPS of AI performance provided by the Jetson Orin Nano architecture is the exact silicon baseline needed to make this deployment practical in real-world environments.
​2. Current Development Progress
​I am not starting from scratch. I am a young hardware developer with an established background in custom PCB layout and low-level firmware integration.
​Hardware Design: The peripheral telemetry carrier board layout and power distribution networks are already under active hardware design.
​Software Foundation: Preliminary data collection models and signal filter processing code have been mapped out.
​3. Concrete Deliverables to the NVIDIA Ecosystem
​I recognize that hardware allocations are an investment in the developer community. As a high school innovator, I am fully committed to thorough documentation and open-source practices. If supported with an Orin Nano Developer Kit, I will provide:
​Production-Ready Open Source Repository: A fully documented public GitHub repository featuring the complete Omni Guard system architecture, firmware layout, and TensorRT model quantization workflows.
​Comprehensive Technical Case Study: A deep-dive article posted here on the NVIDIA Developer Forums showcasing how independent student developers can leverage Jetson hardware for real-world smart-city infrastructure monitoring on a realistic budget.
​Empirical Performance Benchmarks: Hard testing data tracking processing latency, thermal efficiency under sustained inference loads, and power management profiles inside fanless, sealed industrial enclosures.
​I am ready to demonstrate exactly what can be achieved when high-performance NVIDIA hardware is paired with independent student innovation. I would deeply appreciate any guidance, support, or direct allocation opportunities your team can offer to help bring Project Omni Guard to life.
​Thank you for your time, consideration, and continued support of the global developer community.
​Best regards,
​Dipesh Kachhi
Independent Hardware Developer & Student Innovator
Thanks for your interest in building with NVIDIA Jetson. Sponsorship requests aren’t handled directly through the forum, but you may want to explore the NVIDIA Academic Grant Program for Researchers, which is one avenue where teams and researchers can apply for hardware support:
Academic Grant Program for Researchers | NVIDIA
We’re excited to see what you build with Jetson and encourage you to continue sharing your work with the developer community.
Thank you Team for your interest in my project , But
this is for unversity students but I am a high school student.
I’m not able to help as this is handled by other team. Sorry for that.
Okay,
Thanks for considering my project worthy of it .
