Project working on Tegra K1/CUDA 6.5, but not on CUDA 8.0 laptop
I’m usually working on a Jetson TK1 with CUDA 6.5, but wanted to run the project on my Ubuntu 16.04 laptop; I installed CUDA 8.0 and compiled/run the examples, but my code does not compile.
I’m using a GTX 980M with NVIDIA drivers version 364.19 (installed with the package), CUDA 8.0 (installed with the run file), and g++ version 5.4.0
I’m compiling my C++ code using:
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -fPIC -std=c++0x ${BASE_FLAGS} ${GPROF_FLAGS}")
my CUDA code using:
set(CUDA_NVCC_FLAGS ${CUDA_NVCC_FLAGS} -O3 --ptxas-options=-v -g -std=c++11 --maxrregcount 255 -lineinfo)
cuda_add_library(cuda_prgm STATIC
 ../path/to/file.h
 ../path/to/file.cu
and linking with:
add_library(prgm SHARED ${prgm_src_list} ${third_party_list})
target_link_libraries(prgm ${common_libraries} )
target_link_libraries(prgm ${CMAKE_BINARY_DIR}/lib/libcuda_prgm.a)
The verbose Makefile output:
[ 91%] Linking CXX executable ../../bin/cam_viewer
cd /home/jd/dev/prgm/_build/apps/cam && /usr/bin/cmake -E cmake_link_script CMakeFiles/cam_viewer.dir/link.txt --verbose=1
/usr/bin/c++    -Wall -fPIC -std=c++0x -DPARALLEL_NONE -DCOMPILE_PYTHON_BINDINGS  -O3 -DNDEBUG -O3 -DNDEBUG   CMakeFiles/cam_viewer.dir/cam_viewer.cpp.o  -o ../../bin/cam_viewer  -L/usr/lib/x86_64-linux-gnu/libpython2.7.so -rdynamic  ../../lib/libprgm.so /usr/lib/x86_64-linux-gnu/libopencv_calib3d.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_objdetect.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_ml.so.2.4.9 -lpython2.7 -lboost_system -lboost_chrono -lboost_python -lboost_thread -lboost_filesystem -lboost_date_time -lboost_atomic -lpthread /usr/local/cuda/lib64/libcudart_static.a -lpthread -ldl -lrt -lcam -ldl /usr/lib/x86_64-linux-gnu/libopencv_features2d.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_flann.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_imgproc.so.2.4.9 /usr/lib/x86_64-linux-gnu/libopencv_core.so.2.4.9 -lrt -lcam ../../lib/libcuda_prgm.a -Wl,-rpath,/usr/lib/x86_64-linux-gnu/libpython2.7.so:/home/jd/dev/prgm/_build/lib
/usr/bin/ld: ../../bin/cam_viewer: hidden symbol `cudaSetupArgument' in /usr/local/cuda/lib64/libcudart_static.a(libcudart_static.a.o) is referenced by DSO
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
apps/cam/CMakeFiles/cam_viewer.dir/build.make:116: recipe for target 'bin/cam_viewer' failed
make[2]: *** [bin/cam_viewer] Error 1
make[2]: Leaving directory '/home/jd/dev/prgm/_build'
CMakeFiles/Makefile2:776: recipe for target 'apps/cam/CMakeFiles/cam_viewer.dir/all' failed
make[1]: *** [apps/cam/CMakeFiles/cam_viewer.dir/all] Error 2
make[1]: Leaving directory '/home/jd/dev/prgm/_build'
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
(same error for multiple other files)
I tried to inspect the lib, “nm /usr/local/cuda/lib64/libcudart_static.a | grep cudaSetupArg”, but “cudaSetupArgument” doesn’t really seems hidden.
000000000003e720 T cudaSetupArgument
0000000000001590 r _ZZ17cudaSetupArgumentE12__FUNCTION__
Thanks in advance for your time,
any solutions?
any solutions?
I changed my library with the CUDA code from static to shared; not exactly what at wanted, but at least, it compiles and works.
Still unsure why it was working on another device but not my laptop.
