I had a cuda program running for the best part of 36 hours, and now the computer is all but stalled. For starters, whereas each iteration used to take 10 seconds, it now takes 800. SSH connections in now take about 30 seconds to resolve.
I then close the cuda program and the problem does not resolve. Note that the computer’s sole purpose is to run this cuda program.
What’s worse is that rebooting the computer does not fix the issue!
Has anyone got a clue what’s going on here???
Nvidia-smi output (one of the 8 gpus) below (all 8 gpus show similar outputs):
GPU 0000:86:00.0
Product Name : GeForce GTX TITAN
Display Mode : N/A
Display Active : N/A
Persistence Mode : Disabled
Accounting Mode : N/A
Accounting Mode Buffer Size : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-39325139-a5b1-083b-0252-b3e4dc505f84
VBIOS Version : 80.10.2C.00.06
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x86
Device : 0x00
Domain : 0x0000
Device Id : 0x100510DE
Bus Id : 0000:86:00.0
Sub System Id : 0x84511043
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Link Width
Max : N/A
Current : N/A
Fan Speed : 33 %
Performance State : N/A
Clocks Throttle Reasons : N/A
Memory Usage
Total : 6143 MB
Used : 14 MB
Free : 6129 MB
Compute Mode : Default
Utilization
Gpu : N/A
Memory : N/A
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending : N/A
Temperature
Gpu : 49 C
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : N/A
SM : N/A
Memory : N/A
Compute Processes : N/A
