My use of cudaGraphicsGLRegisterBuffer() in combination with an openGL context established using glfw causes a segfault:
Program received signal SIGSEGV, Segmentation fault.
0x0000000000000000 in ?? ()
(cuda-gdb) bt
#0 0x0000000000000000 in ?? ()
#1 0x0000000000419c9b in GLInstance::initialize(std::shared_ptr<SoftmaxSettings>&, std::shared_ptr<SoftmaxData>&) ()
#2 0x00000000004154dc in main ()
(cuda-gdb)
Where the instruction at that address is attempting to load some __glewBindBuffer data:
0x00419c9b 488b05268b2f. mov rax, qword [obj.__glewBindBuffer]
After some reading of examples it looked like I should be explicitly setting the device via cudaGLSetGLDevice() after creating the openGL window; which returns the error:
GPUassert: cannot set while device is active in this process src/GLInstance.cu 27
What should be the proper sequence here, or perhaps I am missing some step? Let me know if I can provide any more information; there are two devices of 3.0 capability available, though I am only attempting to use one at the moment. And of course here’s a full code snippet:
void GLInstance::initialize(std::shared_ptr<SoftmaxSettings>& aSoftmaxSettings,
std::shared_ptr<SoftmaxData>& aSoftmaxData)
mDrawSize = aSoftmaxData->hostPoints.size();
if (!glfwInit())
fprintf(stderr, "ERROR: could not start GLFW3\n");
mWindow = glfwCreateWindow(aSoftmaxSettings->windowWidth, aSoftmaxSettings->windowHeight, "Cuda Regression", NULL, NULL);
glfwSetWindowPos(mWindow, 1920 - 2*aSoftmaxSettings->windowWidth - 2, 0);
if (!mWindow)
fprintf(stderr, "ERROR: could not openmWindow with GLFW3\n");
glfwTerminate();
glfwSetInputMode(mWindow, GLFW_STICKY_KEYS, GL_TRUE);
glfwSetInputMode(mWindow, GLFW_CURSOR, GLFW_CURSOR_DISABLED);
glfwPollEvents();
glfwSetCursorPos(mWindow, aSoftmaxSettings->windowWidth/2, aSoftmaxSettings->windowHeight/2);
glfwMakeContextCurrent(mWindow);
glDepthFunc(GL_LESS);
//gpuErrchk(cudaSetDevice(0));
gpuErrchk(cudaGLSetGLDevice(0));
// mPosition Buffer Array
mPointsVBO = 0;
glGenBuffers(1, &mPointsVBO);
glBindBuffer(GL_ARRAY_BUFFER, mPointsVBO);
glBufferData(GL_ARRAY_BUFFER, aSoftmaxData->hostPoints.size()*sizeof(float3), aSoftmaxData->hostPoints.data(), GL_STATIC_DRAW);
gpuErrchk(cudaGraphicsGLRegisterBuffer(&mCudaPointsResource, mPointsVBO, cudaGraphicsMapFlagsReadOnly));
// Color Buffer Array
mColorsVBO = 0;
glGenBuffers(1, &mColorsVBO);
glBindBuffer(GL_ARRAY_BUFFER, mColorsVBO);
glBufferData(GL_ARRAY_BUFFER, aSoftmaxData->hostColors.size()*sizeof(float3), aSoftmaxData->hostColors.data(), GL_DYNAMIC_DRAW);
gpuErrchk(cudaGraphicsGLRegisterBuffer(&mCudaColorResource, mColorsVBO, cudaGraphicsMapFlagsNone));
