Prototype doesn't match for....
I have an issue with the pgfortran compiler, version 1.3 on Linux.
I am getting an error message ’ nvlink error: Prototype doesn’t match for ‘kernel_functions_grad_w_cubic_corrected_’ when linking my code - attached below.
I think this is because I am being tricky and returning an array of values from a function. Could you let me know if this is the case and if there is any way to get this to work?
Thanks in advance
Tim.
      function grad_w_cubic_corrected(r,h,dx,dy,dz,ci)
      !$acc routine seq
      real*4 dx,dy,dz,h
      real*4 ci(2:4,1:4)
      real*4 r,q,pi,norm_val,w_cubic
      real*4 gx_correction_val
      real*4 gy_correction_val
      real*4 gz_correction_val
      real, dimension(3) :: grad_w_cubic_corrected
      pi = 3.1415926535897932384626433832795028841971693993
      q = r/h
      norm_val = 3.0/(2.0*pi*h*h*h) ! 3-d
      if(q.gt.0.0.and.q.le.1.0) then
       w_cubic = norm_val * ((2.0/3.0) - (q*q) + (0.5*q*q*q))
      elseif(q.gt.1.0.and.q.le.2.0) then
       w_cubic = norm_val * ((1.0/6.0) * ((2.0-q)**3.0))
      else
       w_cubic = 0.00
      endif
      gx_correction_val = ci(2,1) + (ci(2,2)*dx) +                    &
                                        (ci(2,3)*dy)  + (ci(2,4)*dz)
      gy_correction_val = ci(3,1) + (ci(3,2)*dx) +                    &
                                        (ci(3,3)*dy)  + (ci(3,4)*dz)
      gz_correction_val = ci(4,1) + (ci(4,2)*dx) +                    &
                                        (ci(4,3)*dy)  + (ci(4,4)*dz)
      grad_w_cubic_corrected(1) = w_cubic * gx_correction_val * -1.0
      grad_w_cubic_corrected(2) = w_cubic * gy_correction_val * -1.0
      grad_w_cubic_corrected(3) = w_cubic * gz_correction_val * -1.0
      end function grad_w_cubic_corrected
Hi Tim,
I was able to recreate the error here and have assigned it to TPR#21688. The generated device code all looks ok to me, so I’ll need to have one of the compiler engineers investigate why the error occurs.
Unfortunately, the only work around I can find is to pass in an array rather than returning it.
Also, if you can, please send a reproducing example to PGI Customer Service (trs@pgroup.com). While I think I replicated the issue, it’s always nice to have the original problem just in case.
Thanks,
Mat
Hi Mat,
I have emailed you files to form a reproducing example.
Thanks for your help :-)
Tim.
