I am evaluating the possibility of running Proxmox VE on NVIDIA Jetson platforms, specifically Jetson AGX Orin and Jetson Thor.
Proxmox VE is a virtualization platform for running KVM virtual machines and LXC containers.
Can Nvidia Jetson AGX Orin / Jetson Thor be supported as UEFI+ACPI ARM64 platforms capable of running standard server distributions and virtualization stacks such as Proxmox VE?
Both Jetson AGX Orin and Jetson Thor provide UEFI, and NVIDIA public docs state that with SMBIOS/ACPI, UEFI can load a generic OS.
However, based on currently public documentation, they should not be described as officially supported ARM64 server platforms for standard server distributions or Proxmox VE, especially since AGX Orin still relies on Jetson-specific BSP and DTB/FDT integration.
I could not find any documented public procedure or UEFI menu option to switch Jetson Thor from device tree to ACPI.
In the current published flow, Jetson Thor is still documented as DT-based, and UEFI loads the kernel image and DTB from /boot/extlinux/extlinux.conf when specified.
