• Hardware (T4/V100/Xavier/Nano/etc)
Ubuntu 20, x86, RTX3090
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
Detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I’ve retrained a model by my own small dataset with training epoch 40 and batch size 4, the average precision shows all good in training and evaluate stage, when comes to prune stage, what ever I put the value in pth
(tried default 5.2e–6, 7.0e–6, 7.2e–6, 9.9e–6, 0.01), it always show pruned result with ratio 1.
I’m sure it works days ago with another similar custom model, no idea what’s going on here:
!tao detectnet_v2 prune \
-m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/resnet18_detector.tlt \
-o $USER_EXPERIMENT_DIR/experiment_dir_pruned/resnet18_nopool_bn_detectnet_v2_pruned.tlt \
-eq union \
-pth 0.0000070 \
-k $KEY
2022-01-24 13:23:22,611 [INFO] root: Registry: [‘nvcr.io’]
2022-01-24 13:23:22,639 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
2022-01-24 13:23:22,648 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/ewew/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2022-01-24 05:23:27,161 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-01-24 05:23:27,436 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2022-01-24 05:23:34,049 [INFO] iva.common.magnet_prune: Pruning ratio (pruned model / original model): 1.0
2022-01-24 05:23:34,463 [INFO] root: Pruning ratio (pruned model / original model): 1.0
2022-01-24 05:23:34,463 [INFO] root: {
“pruning_ratio”: 1.0,
“size”: 42.937171936035156,
“param_count”: 11.203023
2022-01-24 13:23:35,091 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
