I’ve enjoyed exploring the Jetson Nano’s potential as an inexpensive tool for ML projects. What I haven’t enjoyed as much has been tracking down dependencies, conflicts, etc. for my favorite packages. So, in an effort to save everyone some time and trouble, here is a process I’ve found works well to create an up-to-date image with:
- JetPack 4.2.2
- The JetCard add-ons:
- PyTorch
- TensorFlow
- Jupyter Lab Server
- SciPy
- Keras
- Seaborn
- Scikit-image
- Scikit-learn
and their associated dependencies (e.g. NumPy, Matplotlib, Pandas)
First, download the Jetson Nano JetPack 4.2.2 image at:
and install and configure it on your Nano, with either WiFi or Ethernet internet access.
Next, open a terminal - here is the sequence of commands to install everything:
sudo apt-get update
git clone -b jetpack_4.2.1 --single-branch GitHub - NVIDIA-AI-IOT/jetcard: An SD card image for web programming AI projects with NVIDIA Jetson Nano
cd jetcard
./install.sh my_jetson_password
sudo apt-get install -y libatlas-base-dev gfortran
sudo pip3 install scipy
sudo pip3 install keras
sudo pip3 install seaborn
sudo pip3 install scikit-image
sudo pip3 install scikit-learn
Each install will take some time, so you’ll want to have a cup or two (or pot or two) of coffee handy while you do this.
After you’re done, you can test things by opening a Jupyter notebook at http://my_jetson_ip_address:8888 and running some code.
One last tip: since memory is so constrained on the Nano, you may find it a good idea to follow the following procedure before running any memory-intensive code:
- Reboot the Nano;
- Log in via ssh;
- Type in the following command to unload the graphic shell, and free up memory for your code:
sudo systemctl isolate multi-user.target
