Software Version
DRIVE OS 6.0.8.1
[-] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[-] Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
[-] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi, I have a PTP GM connected to the eqos_0 port and a lidar connected to mgbe1_0.
I am running following command for Orin PTP sync
ptp4l -i eqos_0 -p /dev/ptp4 -m -l7 -4
and see following output
ptp4l[8315.158]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[8315.158]: port 1: received link status notification
ptp4l[8315.158]: interface index 3 is up
ptp4l[8315.866]: port 1: setting asCapable
ptp4l[8316.766]: port 1: new foreign master 002166.fffe.0859cb-1
ptp4l[8320.366]: selected best master clock 002166.fffe.0859cb
ptp4l[8320.366]: updating UTC offset to 37
ptp4l[8320.366]: port 1: LISTENING to UNCALIBRATED on RS_SLAVE
ptp4l[8321.908]: port 1: delay timeout
ptp4l[8321.909]: delay filtered 263578 raw 263578
ptp4l[8322.166]: master offset -613662061805 s0 freq -5323 path delay 263578
ptp4l[8323.066]: master offset -613662060491 s1 freq -4009 path delay 263578
ptp4l[8323.383]: port 1: delay timeout
ptp4l[8323.966]: master offset -6762 s2 freq -10771 path delay 263578
ptp4l[8323.966]: port 1: UNCALIBRATED to SLAVE on MASTER_CLOCK_SELECTED
ptp4l[8324.866]: master offset 3138 s2 freq -2900 path delay 263578
ptp4l[8325.410]: port 1: delay timeout
ptp4l[8325.411]: delay filtered 237196 raw 210815
ptp4l[8325.766]: master offset 25644 s2 freq +20548 path delay 237196
ptp4l[8325.892]: port 1: delay timeout
ptp4l[8325.893]: delay filtered 210815 raw 209977
For lidar PTP sync I am using the following command but lidar is not getting PTP synced.
sudo ptp4l -i mgbe1_0 -p /dev/ptp3 -m -l7
ptp4l[8424.565]: config item /var/run/ptp4l.min_neighbor_prop_delay is -20000000
ptp4l[8424.565]: config item (null).uds_address is '/var/run/ptp4l'
ptp4l[8424.565]: port 0: INITIALIZING to LISTENING on INIT_COMPLETE
ptp4l[8424.565]: port 1: received link status notification
ptp4l[8424.565]: interface index 5 is up
ptp4l[8432.547]: port 1: announce timeout
ptp4l[8432.548]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[8432.548]: selected local clock 48b02d.fffe.d2f099 as best master
ptp4l[8432.548]: assuming the grand master role
ptp4l[8432.549]: port 1: master tx announce timeout
ptp4l[8432.549]: port 1: setting asCapable
ptp4l[8433.548]: port 1: master sync timeout
ptp4l[8434.548]: port 1: master sync timeout
ptp4l[8434.549]: port 1: master tx announce timeout
ptp4l[8435.548]: port 1: master sync timeout
ptp4l[8436.548]: port 1: master sync timeout
ptp4l[8436.549]: port 1: master tx announce timeout
Are there any more setting that needs to take place?
