Windows 7 (32 bit), VS 2008 SP1, CUDA 3.0.
Trying to compile the “BlackScholes” example in the CUDA SDK. This worked fine under Windows XP, btw.
Here is the output from VS 2008 build (passing “verbose” to nvcc):
Compiling with CUDA Build Rule...
... (eventually we get to the nvopencc phase)
#$ nvopencc -TARG:compute_10 -m32 -CG:ftz=1 -CG:prec_div=0 -CG:prec_sqrt=0 -LIST:source=on "BlackScholes.compute_10.cpp3.i" -o "BlackScholes.compute_10.ptx"
The BlackScholes.compute_10.ptx is chopped off in the middle, as if the last part of the file was not flushed to disk. As a result, the subsequent ptxas phase fails:
#$ ptxas --key="28ecf09ecc97029e" -arch=sm_10 -m32 -v -maxrregcount=32 "BlackScholes.compute_10.ptx" -o "BlackScholes.compute_10.sm_10.cubin"
ptxas BlackScholes.compute_10.ptx, line 94; fatal : Parsing error near '': syntax error
ptxas fatal : Ptx assembly aborted due to errors
Has anybody seen this before?
