I am developing a custom PyCodelet that receives a ColorCameraProto, extracts camera intrinsics, and publishes them as a TensorListProto. I have followed the PyCodelet tutorial and have successfully received the ColorCameraProto and initialized the TensorListProto, but I cannot figure out how to add my data to the TensorListProto. The SDK documentation says the Data field is formatted as raw bytes. How would I assign a NP array to this field?
The code I have tried is below:
class PinholeToTensor(Codelet):
def start(self):
# This part will be run once in the beginning of the program
print("Running initialization")
# Input and output messages for the Codelet
self.rx = self.isaac_proto_rx("ColorCameraProto", "rgb_image")
self.tx = self.isaac_proto_tx("TensorListProto", "tensor_list")
self.tx_inner = self.isaac_proto_tx("TensorProto", "tensor")
# Tick every time we receive an image
self.tick_on_message(self.rx)
def tick(self):
print("Ticking")
# Extract pinhole proto from rx
pinhole = self.rx.get_proto().pinhole
# Extract proto attributes
focal_x = pinhole.focal.x
focal_y = pinhole.focal.y
center_x = pinhole.center.x
center_y = pinhole.center.y
# Create 1D camera matrix
camera_mat = [int(focal_x), 0, int(center_x),
0, int(focal_y), int(center_y),
0, 0, 1]
# Initialize TensorProto and TensorListProto for the camera matrix
tx_message = self.tx.init_proto()
tx_contents = self.tx_inner.init_proto()
# Set element type
tx_contents.elementType = 2
# Set tensor dimensions
size = tx_contents.init('sizes', 2) # = [1, 9]
size[0] = 9
size[1] = 1
# Add data to TensorProto
data = tx_contents.init('data',len(camera_mat))
for i in range(len(camera_mat)):
data[i] = camera_mat[i] ## ERROR HERE ##
# Create TensorList
tensor_list = tx_message.init('tensors', 1)
# Add tensor to TensorListProto
tensor_list[0] = tx_contents
# Publish TensorListProto
self.tx.publish()
When I run this, I get the following error:
TypeError: ‘bytes’ object does not support item assignment
