Publishing rotation Static transform
Hello ,
I want to publish a static transform, rotated a certain amount from a link.
I tried using ROS2PublishRawTransformTree , not sure how to set the rotation port.
What node can I use to generate a fixed rotation ?
Sandeep
Hello All,
Just to clarify , I want to achieve the equivalent of the following command in an action graph
ros2 run tf2_ros static_transform_publisher 0 0 0 0 0 -1.571 Camera_IMU_1 Camera_IMU_1_rot
this creates a frame “Camera_IMU_1_rot” which is rotated -90 deg on the X axis from Camera_IMU_1.
