Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.7.0.8846
Host Machine Version
native Ubuntu 18.04
I run demo nvsipl_camera using the following configuration:
./nvsipl_camera --platform-config "F008A120RM0A_CPHY_x4" --link-enable-masks "0x0011 0x0001 0x0001 0x0000" --showfps -1
USE: camera group A B C , and totally four cameras. About 48 hours later, I got the following error log:
Output
Sensor0_Out1 Frame rate (fps): 29.9985
Sensor1_Out1 Frame rate (fps): 29.9985
Sensor4_Out1 Frame rate (fps): 29.9985
Sensor8_Out1 Frame rate (fps): 29.9985
DEVBLK_MON_1: /dvs/git/dirty/git-master_linux/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 573: ThreadFunc: DeviceBlock: 1, deserializer error: 0
nvsipl_camera: ERROR: DeviceBlock: 1, NOTIF_ERROR_DESERIALIZER_FAILURE
DevBlkEvent: CNvMDeviceBlock.cpp: 1087: GetErrorGPIOEventInfo: DevBlkCDIRootDeviceGetGpioIntrEvent with NvMedia error: 6
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 2707
Module_id 30 Severity 2 : MAX96712: global ERRB status 0x0000de
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 2881
Module_id 30 Severity 2 : MAX96712: pipeline overflow 1
nvmedia: ERROR: MAX96712: pipeline 1: cmd overflow error
Module_id 30 Severity 2 : MAX96712: pipeline overflow 5
nvmedia: ERROR: MAX96712: pipeline 5: cmd overflow error
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 3010
Module_id 30 Severity 2 : MAX96712: GMSL2 decoding error 0 1
Module_id 30 Severity 2 : src/devblk/nonfusa/devices/MAX96712DeserializerDriver/cdi_max96712.c 3060
Module_id 30 Severity 2 : MAX96712: Video pixel crc count 0 1
DeviceBlock[1] Deserializer Error Buffer: � b b b
nvsipl_camera: ERROR: DeviceBlock: 1, Deserializer link error. mask: 1
Output
Sensor0_Out1 Frame rate (fps): 29.9984
Sensor1_Out1 Frame rate (fps): 29.9984
Sensor4_Out1 Frame rate (fps): 29.9984
Sensor8_Out1 Frame rate (fps): 29.9984
nvsipl_camera: ERROR: Device Block failure
somebody help me~, why and how to solve this problem
