Pull access denied for nvcr.io/nvidia/clara-train,repository does not exist or may require'dockerlogin': denied:requestedaccess to theresourceisdenied
Unable to run AIAA, can someone assist
Hi
Thanks for your interest in Clara Train SDK. There is a typo in the pull command missing the “v” in the tag
Can you simply try the pull as
docker pull nvcr.io/nvidia/clara-train-sdk:v4.1
you will then need to change the docker compose file
