Pull the drive os docker image error
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
We refer to the Drive OS installation tutorial:
But the following error occurs, why?
zhangzs@zhangzs-pc:~$ sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v ${WORKSPACE}:/home/nvidia/ nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest
docker: invalid spec: :/home/nvidia/: empty section between colons.
See ‘docker run --help’.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG…]
Create and run a new container from an image
Dear @deng.shigang ,
Did you set the WORKSPACE variable?
@deng.shigang Since your company has access to NVOnline, that’s the place for you to seek support. Please use NVOnline to get the assistance you need.
how to use NVOnline ?
I try to use deng.shigang@byd.com account login https://partners.nvidia.com/, but prompt “Invalid username or password.”. What am I supposed to do?
Please reach out to your nvidia representative on the access problem.
