In the below funtion we found like dtb is converted to dts while flashing the source code with the AGX SoM . So, could you please explain why dtb is converted to dts while flashing? @WayneWWW
#Convert the DTB to DTSI
def tegraflash_bpmp_generate_int_dtsi(bpmp_dtb_dir, bpmp_dtb_path):
( In the tegraflash_internal.py file )
