The older a02 revision carrier board had only one CSI connector, whereas the one you are working with is a b01 revision. The header which you will find under the module (which is subtle, you have to look for it), sandwiched between the module and carrier board nearest to the end with the CSI connectors, but along that back long edge, contains the pins you need to access.
Basically there is a recovery pin, and a ground on one side next to it. This works like a “shift key” on a keyboard…if you hold it down while powering up or cycling power, then the Jetson starts in recovery mode (you simply short/jumper the pin to ground pin next to it until power is applied, and then remove the jumper).
Recovery mode does not actually make changes, but it does turn the Jetson into a custom USB device which flash software understands.
There is a post with a list of various URLs here:
https://forums.developer.nvidia.com/t/links-to-jetson-nano-resources-wiki/71639
You would be interested in this:
https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit
Here is where you can download almost any document (you might need to go there, log in, and then go there again if redirect fails):
https://developer.nvidia.com/embedded/downloads#?tx=$product,jetson_nano
This document may be of interest since this considers using the SDK Manager. Understand that there are actually two models of Jetsons, one runs from the SD card and is provided with the development kit, and another model is sold as module only and uses eMMC instead of SD card. Much of the information is the same for either, but with the SD card model you can perform certain steps directly on the SD card rather than flashing, or you can flash. The eMMC model can only flash. The document:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
This link has some general information:
https://elinux.org/Jetson_Nano
More detail on the recovery pin is that this is connector J14
, pins 9 and 10. If you face the long edge of the carrier board on the side opposite to where most of the connectors are you will see a single row header between carrier board and module. This has a silkscreen marking pins. Looking at the edge under the module the left end will be pin 1, and the right side (closest to the standoff holding the module) will have a marking for “PWR BTN
”. Just left of that is a pin marked “GND
”. If the unit were off and you momentarily shorted those two, then the Nano would power up. The two pins to the left of this are for recovery mode button and another ground. Shorting those as power is applied or reset means the Jetson will be in recovery mode. I think that particular header is probably the same on both a02 and b01 revisions.
