PVF 13.4 compiler?
Started out with the routine (edited to be simpler) as shown:
!DK STATIONARY_RECHECK
      SUBROUTINE STATIONARY_RECHECK
      IMPLICIT NONE
      INCLUDE 'paramset.fi'
      INCLUDE 'dziinfo.fi'
      INCLUDE 'gopt.fi'
      INCLUDE 'gtime.fi'
      INCLUDE 'heating.fi'
      INCLUDE 'sites.fi'
      INCLUDE 'stationary.fi'
      INCLUDE 'stem_status.fi'
      INCLUDE 'vapor.fi'
      INCLUDE 'write.fi'
! Local variables
      INTEGER :: i, j, k, idiff, idiff_last
      INTEGER :: min_num_occurances
      INTEGER :: count_min_sites
      INTEGER, DIMENSION(ndrymax) :: tau_counter
      INTEGER, DIMENSION(ndrymax) :: mult_min_sites
      INTEGER, DIMENSION(100,ndrymax) :: stems_each_multiple
!     RECHECK HOVERING PERIODS BASED ON THE ONES THAT OCCUR INFREQUENTLY.
!     LONG STATIONARY PERIODS NOT FOUND MIGHT BE BASED ON THESE.
      min_num_occurances = COUNTCHANGINGSITES(1)
      mult_min_sites(1) = CHANGINGSITES(1)
      count_min_sites = 1
      DO i=2,countchanging
         IF ( COUNTCHANGINGSITES(i)<=min_num_occurances ) THEN
            IF ( COUNTCHANGINGSITES(i)==min_num_occurances ) THEN
               count_min_sites = count_min_sites + 1
               mult_min_sites(count_min_sites) = CHANGINGSITES(i)
            ELSE
               min_num_occurances = COUNTCHANGINGSITES(i)
            ENDIF
         ENDIF
      ENDDO
      DO j=1,total_num_taus
         tau_counter(j) = 0
      ENDDO
      WRITE (6,99030) count_min_sites
      WRITE (6,99040) (mult_min_sites(i),i=1,count_min_sites)
      RETURN
!     FORMAT STATEMENTS
99030 FORMAT (//,i3,' multiple sites with least number of intermediate activations')
99040 FORMAT ('   Sites are', 10i4)
      END SUBROUTINE STATIONARY_RECHECK
The problem lies in this section of code
         tau_counter(j) = 0
      ENDDO
It overwrites
with zeros.
To show this, I put write statements around that section of the code, i.e.
         tau_counter(j) = 0
      ENDDO
that produces the following two lines of printout
Sites are 15 143
Sites are 0 0
I can move the problem code to the first executable part of the routine so that
      IMPLICIT NONE
      INCLUDE 'gopt.fi'
      INCLUDE 'gtime.fi'
      INCLUDE 'sites.fi'
      INCLUDE 'vapor.fi'
      INCLUDE 'write.fi'
! Local variables
         tau_counter(j) = 0
      ENDDO
      count_min_sites = 1
            ELSE
            ENDIF
         ENDIF
      ENDDO
and the correct output is yielded.
Using PVF 13.4, with the following compiler options:
-Bstatic -Mbackslash -I"F:\Macro3d\PGI\PGI_5-5-2013\Include Files" -I"d:\program files\pgi\win64\13.4\include" -I"D:\Program Files\PGI\Microsoft Open Tools 11\include" -I"D:\Program Files\PGI\Microsoft Open Tools 11\PlatformSDK\include" -fastsse -Mipa=fast,inline -O3 -Mvect=simd:256 -Minline -Munroll=n:4 -Mconcur -tp=sandybridge-64 -Minform=warn -Mkeepasm -Minfo=accel,ftn,inline,loop,opt,par,vect
Is there a problem or did I miss something?
Thanks for your assistance.
Hi Ralph,
What’s the values for “ndrymax” and “total_num_taus”?
My best guess is that you’re writing beyond the end of “tau_counter”. When using “-Mconcur” or “-mp”, automatics are allocated on the stack, meaning that if you are writing beyond the end of “tau_counter”, you’re writing in “mult_min_sites”.
If that’s not it, then I’ll need a reproducing example to determine the cause.
  • Mat
Matt,
Yes, that’s it. Loop should be out to ndrymax, not total_num_taus. Thanks.
If I turn on array bounds checking, how would it show me the problem? An output file somewhere or does the program stop. Assume it would slow the program execution down significantly?
-ralph
Hi Ralph,
If the bounds of the array is known, which is the case here, then yes.
The program stops. It will slow it down a bit but not significantly. It’s not a flag you’d use for your final production, just during debugging.
  • Mat
Matt,
Only debugging?
Strange it shows up as an option within the PVF options (run-time options under VS2008) when you’ve selected highly optimized, etc. It must have reset things without telling me — still seems to indicate it is a released version within the properties but runs very slowly (like a debug version).
Glitch in the interface? Of course, I could be the glitch.
-ralph
Only debugging?
You could put it in a production build, I just wouldn’t recommend it. Hopefully by the time you get to that point you shouldn’t need it.
  • Mat
