hi when I compile OPENACC with GPU card NVS4200m in PVF12.8 it
returned an error call to cuMemcpyDtoH returned error 999 Unknow
program laplace
!#ifdef _OPENACC
use openacc
!#endif
implicit none
integer, parameter :: fp_kind=kind(1.0)
integer, parameter :: n=4096, m=4096, iter_max=1000
integer :: i, j, iter
real(fp_kind), dimension (:,:), allocatable :: A, Anew
real(fp_kind), dimension (:), allocatable :: y0
real(fp_kind) :: pi=2.0_fp_kind*asin(1.0_fp_kind), tol=1.0e-5_fp_kind, error=1.0_fp_kind
real(fp_kind) :: start_time, stop_time
allocate ( A(0:n-1,0:m-1), Anew(0:n-1,0:m-1) )
allocate ( y0(0:m-1) )
A = 0.0_fp_kind
! Set B.C.
y0 = sin(pi* (/ (j,j=0,m-1) /) /(m-1))
A(0,:) = 0.0_fp_kind
A(n-1,:) = 0.0_fp_kind
A(:,0) = y0
A(:,m-1) = y0*exp(-pi)
!#if _OPENACC
call acc_init(acc_device_nvidia)
!#endif
write(*,'(a,i5,a,i5,a)') 'Jacobi relaxation Calculation:', n, ' x', m, ' mesh'
call cpu_time(start_time)
iter=0
!$omp parallel do shared(Anew)
do i=1,m-1
Anew(0,i) = 0.0_fp_kind
Anew(n-1,i) = 0.0_fp_kind
end do
!$omp end parallel do
do i=1,n-1
Anew(i,0) = y0(i)
Anew(i,m-1) = y0(i)*exp(-pi)
end do
!$acc data copy(A), create(Anew)
do while ( error .gt. tol .and. iter .lt. iter_max )
error=0.0_fp_kind
!$omp parallel do shared(m, n, Anew, A) reduction( max:error )
!$acc kernels loop gang(32), vector(16)
do j=1,m-2
!$acc loop gang(16), vector(32)
do i=1,n-2
Anew(i,j) = 0.25_fp_kind * ( A(i+1,j ) + A(i-1,j ) + &
A(i ,j-1) + A(i ,j+1) )
error = max( error, abs(Anew(i,j)-A(i,j)) )
end do
!$acc end loop
end do
!$acc end kernels
if(mod(iter,100).eq.0 ) write(*,'(i5,f10.6)'), iter, error
iter = iter +1
!$acc kernels loop
do j=1,m-2
do i=1,n-2
A(i,j) = Anew(i,j)
end do
!$acc end loop
end do
!$acc end kernels
end do
!$acc end data
call cpu_time(stop_time)
write(*,'(a,f10.3,a)') ' completed in ', stop_time-start_time, ' seconds'
deallocate (A,Anew,y0)
end program laplace
