I am using deepstream-imagedata-mulitstream for person detection. And for person detection, I am using my custom train yolov4 model. Now I want to create a single exe for my project and for that I am using pyinstaller.
Now in Pyinstaller whenever I am using --ondir command everything is working and exe is generating the model.engine file properly. But when I use --onefile for single exe it is not working and throwing error as given below.
terminate called after throwing an instance of 'pwgen::PwgenException’
** what(): Driver error: ** Fatal Python error: Aborted
Hello, this forum is dedicated to discussions related to using the sanitizer tools and API.
Questions related to the Deepstream SDK can be raised at DeepStream SDK - NVIDIA Developer Forums
Could you fill out the following information first?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
• Hardware Platform : Jetson Nano • DeepStream Version : 5.1 • JetPack Version : 4.5.1 • TensorRT Version : 7.1.3.0 • Issue Type: Questions
How to reproduce the issue: Used Deepstream-imagedata-multistream Python module along with yolov4 model for object detection in multiple streams. Now to generate one single exe file I have used pyinstaller. When I use pyinstaller --onefile main.spec file it crashes when engine building module is running. And when I run the script normally using python3 it works properly.
