Hi team,
I am facing a strange issue when trying to run a python script with interrupts and pwm being initialised. The interrupts are being used to keep track of a rotary encoder and the pwm to control a motor.
If I run the script with both the interrupts and pwm set up (using jetson.GPIO), the interrupts no longer work once I start the pwm. I’ve tested and both the interrupts and pwm work if I run them in separately, but as soon as i try to use both the interrupts no longer function. Does anyone know what is causing this issue and how I can fix it?
