PWM backlight
HI NV team!
How do I enable PWM during the bootloader phase?
I need to backlight the screen.
Hi 875225350,
Are you using the devkit or custom board?
May I know what’s the use case for you to config PWM during bootloader?
Do you want to show something on your screen earlier?
custom board.
Jetson_Linux_R35.3.1
I need the orin control backlight to show the BIOS interface.
Do you mean the UEFI menu to configure like boot-order…etc?
Do you connect any external DP monitor?
UEFI menu should show on the display.
UEFI menu.
Use eDP for external display.
I am enabling PWM in Ubuntu.
Lighting the backlight requires access to the operating system.
It’s enabled based on dtb entry.
You could just modify device tree to enable PWM.
