いい加減に返信しろや。
Do you use Xavier developer kit or your own custom board? SDKManager is for developer kit. For your custom board, you would need to modify device tree and build kernel, to enable specific functions on your custom board. The default system image is mainly for developer kit.
nvidiaが出してるちゃんとした(カスタムボードではない)Xavierのデベロッパーキット使ってるよ。
If you use Xavier developer kit, please follow the steps in
PWM cannot be enabled - #15 by JerryChang
After doing step 1 and 2, please rebuild device tree and then re-flash the system. The steps are in Kernel Customization section in developer guide
And then after booting to Ubuntu desktop, please do step 3 and connect the pin to an oscilloscope and check if the signal is as expected.
何回その定型文で済ます気だよ。
言うとおりにやってピンの有効化できなかったって言っただろ。
Please execute the commands and check if the device nodes are present first:
root@nvidia-desktop:/sys/devices/32c0000.pwm/pwm/pwmchip2# echo 0 > export
root@nvidia-desktop:/sys/devices/32c0000.pwm/pwm/pwmchip2# ls
device export npwm power pwm0 subsystem uevent unexport
root@nvidia-desktop:/sys/devices/32c0000.pwm/pwm/pwmchip2# cd pwm0/
root@nvidia-desktop:/sys/devices/32c0000.pwm/pwm/pwmchip2/pwm0# ls
capture double_period enable polarity ramp_time
capture_window_length duty_cycle period power uevent
