please get the logs:
Last login: Sun Jan 28 15:58:30 UTC 2018 on ttyS0
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.9.140 aarch64)
root@localhost:/home/ubuntu#
root@localhost:/home/ubuntu# ls
Desktop examples.desktop
root@localhost:/home/ubuntu# reboot
Ses[ 878.046106] watchdog: watchdog0: watchdog did not stop!
[ 878.055455] systemd-shutdow: 41 output lines suppressed due to ratelimiting
[ 878.386126] tegra-xusb 3530000.xhci: Host not halted after 16000 microseconds.
[ 878.426373] reboot: Restarting system
[0000.049] C> I2C command failed
[0000.052] C> block index = (4) and rail_id = (1)
[0000.057] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.061] C> I2C command failed
[0000.064] C> block index = (5) and rail_id = (1)
[0000.069] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.170] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c700205d)
[0000.179] I> bit @ 0xd480000
[0000.182] I> Boot-device: eMMC
[0000.189] I> sdmmc bdev is already initialized
[0000.194] I> pmic: reset reason (nverc) : 0x0
[0000.214] W> Cannot find any partition table for 00000003
[0000.233] I> Found 34 partitions in SDMMC_USER (instance 3)
[0000.239] W> No valid slot number is found in scratch register
[0000.245] W> Return default slot: _a
[0000.248] I> A/B: bin_type (16) slot 0
[0000.252] I> Loading partition bpmp-fw at 0xd7800000
[0000.257] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.262] I> Addr: 0xd7800000, start-block: 13369352, num_blocks: 1
[0000.287] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.293] W> No valid slot number is found in scratch register
[0000.298] W> Return default slot: _a
[0000.302] I> A/B: bin_type (17) slot 0
[0000.305] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.310] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.316] I> Addr: 0xd79f0000, start-block: 13371768, num_blocks: 1
[0000.337] I> Binary(17) of size 314992 is loaded @ 0xd79b3000
[0000.460] I> Loading SCE-FW âŠ
[0000.463] W> No valid slot number is found in scratch register
[0000.469] W> Return default slot: _a
[0000.472] I> A/B: bin_type (12) slot 0
[0000.476] I> Loading partition sce-fw at 0xd7300000
[0000.481] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.486] I> Addr: 0xd7300000, start-block: 13375864, num_blocks: 1
[0000.505] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.511] I> Init SCE
[0000.513] I> Loading APE-FW âŠ
[0000.516] W> No valid slot number is found in scratch register
[0000.522] W> Return default slot: _a
[0000.525] I> A/B: bin_type (11) slot 0
[0000.529] I> Loading partition adsp-fw at 0xd7400000
[0000.534] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.539] I> Addr: 0xd7400000, start-block: 13352968, num_blocks: 1
[0000.558] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.564] I> Copy BTCM section
[0000.567] W> No valid slot number is found in scratch register
[0000.573] W> Return default slot: _a
[0000.576] I> A/B: bin_type (13) slot 0
[0000.580] I> Loading partition cpu-bootloader at 0x96000000
[0000.585] I> Reading two headers - addr:0x96000000 blocks:1
[0000.591] I> Addr: 0x96000000, start-block: 13332488, num_blocks: 1
[0000.611] I> Binary(13) of size 284816 is loaded @ 0x96000000
[0000.617] W> No valid slot number is found in scratch register
[0000.623] W> Return default slot: _a
[0000.626] I> A/B: bin_type (20) slot 0
[0000.630] I> Loading partition bootloader-dtb at 0x8520f400
[0000.635] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.641] I> Addr: 0x8520f400, start-block: 13334536, num_blocks: 1
[0000.661] I> Binary(20) of size 253872 is loaded @ 0x8520f400
[0000.667] W> No valid slot number is found in scratch register
[0000.672] W> Return default slot: _a
[0000.676] I> A/B: bin_type (14) slot 0
[0000.679] I> Loading partition secure-os at 0x8530f600
[0000.684] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.690] I> Addr: 0x8530f600, start-block: 13336584, num_blocks: 1
[0000.712] I> Binary(14) of size 366000 is loaded @ 0x8530f600
[0000.720] I> TOS boot-params @ 0x85000000
[0000.724] I> TOS params prepared
[0000.727] I> Loading EKS âŠ
[0000.729] I> A/B: bin_type (15) slot 0
[0000.733] I> Loading partition eks at 0x8590f800
[0000.738] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.743] I> Addr: 0x8590f800, start-block: 13348872, num_blocks: 1
[0000.762] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.767] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.772] I> Copied encrypted keys
[0000.776] I> boot profiler @ 0x175844000
[0000.780] I> boot profiler for TOS @ 0x175844000
[0000.785] I> Unhalting SCE
[0000.787] I> Primary Memory Start:80000000 Size:70000000
[0000.792] I> Extended Memory Start:f0110000 Size:856f0000
[0000.799] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:14:44, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing âŠ
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.105] I> Welcome to Cboot
[0001.108] I> Cboot Version: t186-02737b3e
[0001.112] I> CPU-BL Params @ 0x175800000
[0001.115] I> 0) Base:0x00000000 Size:0x00000000
[0001.120] I> 1) Base:0x177f00000 Size:0x00100000
[0001.124] I> 2) Base:0x177e00000 Size:0x00100000
[0001.129] I> 3) Base:0x177d00000 Size:0x00100000
[0001.133] I> 4) Base:0x177c00000 Size:0x00100000
[0001.138] I> 5) Base:0x177b00000 Size:0x00100000
[0001.142] I> 6) Base:0x177800000 Size:0x00200000
[0001.147] I> 7) Base:0x177400000 Size:0x00400000
[0001.152] I> 8) Base:0x177a00000 Size:0x00100000
[0001.156] I> 9) Base:0x177300000 Size:0x00100000
[0001.161] I> 10) Base:0x176800000 Size:0x00800000
[0001.165] I> 11) Base:0x30000000 Size:0x00040000
[0001.169] I> 12) Base:0xf0000000 Size:0x00100000
[0001.174] I> 13) Base:0x30040000 Size:0x00001000
[0001.178] I> 14) Base:0x30048000 Size:0x00001000
[0001.183] I> 15) Base:0x30049000 Size:0x00001000
[0001.187] I> 16) Base:0x3004a000 Size:0x00001000
[0001.192] I> 17) Base:0x3004b000 Size:0x00001000
[0001.196] I> 18) Base:0x3004c000 Size:0x00001000
[0001.201] I> 19) Base:0x3004d000 Size:0x00001000
[0001.205] I> 20) Base:0x3004e000 Size:0x00001000
[0001.209] I> 21) Base:0x3004f000 Size:0x00001000
[0001.214] I> 22) Base:0x00000000 Size:0x00000000
[0001.218] I> 23) Base:0xf0100000 Size:0x00010000
[0001.223] I> 24) Base:0x00000000 Size:0x00000000
[0001.227] I> 25) Base:0x00000000 Size:0x00000000
[0001.232] I> 26) Base:0x00000000 Size:0x00000000
[0001.236] I> 27) Base:0x00000000 Size:0x00000000
[0001.240] I> 28) Base:0x84400000 Size:0x00400000
[0001.245] I> 29) Base:0x30000000 Size:0x00010000
[0001.249] I> 30) Base:0x178000000 Size:0x08000000
[0001.254] I> 31) Base:0x00000000 Size:0x00000000
[0001.258] I> 32) Base:0x176000000 Size:0x00600000
[0001.263] I> 33) Base:0x80000000 Size:0x70000000
[0001.267] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.272] I> 35) Base:0x00000000 Size:0x00000000
[0001.276] I> 36) Base:0x00000000 Size:0x00000000
[0001.280] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.285] I> 38) Base:0x84000000 Size:0x00400000
[0001.289] I> 39) Base:0x96000000 Size:0x02000000
[0001.294] I> 40) Base:0x85000000 Size:0x01200000
[0001.298] I> 41) Base:0x175800000 Size:0x00500000
[0001.303] I> 42) Base:0x00000000 Size:0x00000000
[0001.307] I> 43) Base:0x00000000 Size:0x00000000
[0001.312] GIC-SPI Target CPU: 4
[0001.315] Interrupts Init done
[0001.318] calling constructors
[0001.321] initializing heap
[0001.324] initializing threads
[0001.327] initializing timers
[0001.330] creating bootstrap completion thread
[0001.335] top of bootstrap2()
[0001.338] CPU: ARM Cortex A57
[0001.341] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.346] initializing platform
[0001.350] I> Bl_dtb @0x8520f400
[0001.353] I> gpio framework initialized
[0001.358] I> tegrabl_gpio_driver_register: register ânvidia,tegra186-gpioâ driver
[0001.367] I> tegrabl_gpio_driver_register: register ânvidia,tegra186-gpio-aonâ driver
[0001.375] I> GPIO framework and drivers are initialized.
[0001.380] I> Boot-device: eMMC
[0001.387] I> sdmmc bdev is already initialized
[0001.407] W> Cannot find any partition table for 00000003
[0001.425] I> Found 34 partitions in SDMMC_USER (instance 3)
[0001.430] W> opt-in fuse is not set, skip fuse_burning
[0001.435] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.441] W> No valid slot number is found in scratch register
[0001.447] W> Return default slot: _a
[0001.450] I> A/B: bin_type (21) slot 0
[0001.453] I> Loading kernel-dtb from partition
[0001.458] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.475] I> Kernel_dtb @0x80000000
[0001.478] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.486] E> I2C: slave not found in slaves.
[0001.490] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.498] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.504] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.513] E> tca9539_device_init: failed to write polar reg
[0001.519] E> tegrabl_tca9539_init: failed to init device!
[0001.524] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.530] E> I2C: slave not found in slaves.
[0001.535] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.542] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.548] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.557] E> tca9539_device_init: failed to write polar reg
[0001.563] E> tegrabl_tca9539_init: failed to init device!
[0001.570] I> fixed regulator driver initialized
[0001.597] I> register âmaximâ power off handle
[0001.602] I> virtual i2c enabled
[0001.605] I> registered âmaxim,max77620â pmic
[0001.609] I> tegrabl_gpio_driver_register: register âmax77620-gpioâ driver
[0001.619] I> Find /i2c@c250000âs alias i2c7
[0001.623] I> Reading eeprom i2c=7 address=0x50
[0001.653] I> Device at /i2c@c250000:0x50
[0001.656] I> Reading eeprom i2c=7 address=0x57
[0001.661] E> I2C: slave not found in slaves.
[0001.665] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.673] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.679] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.688] E> eeprom: Failed to read I2C slave device
[0001.693] I> Eeprom read failed 0x3526070d
[0001.697] I> Find /i2c@c240000âs alias i2c1
[0001.701] I> Reading eeprom i2c=1 address=0x51
[0001.707] E> I2C: slave not found in slaves.
[0001.711] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.718] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.724] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.734] E> eeprom: Retry to read I2C slave device.
[0001.739] E> I2C: slave not found in slaves.
[0001.743] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.750] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.756] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.766] E> eeprom: Failed to read I2C slave device
[0001.771] I> Eeprom read failed 0x3526070d
[0001.775] I> Find /i2c@3160000âs alias i2c0
[0001.779] I> Reading eeprom i2c=0 address=0x50
[0001.808] I> Device at /i2c@3160000:0x50
[0001.812] I> Find /i2c@3180000âs alias i2c2
[0001.816] I> Reading eeprom i2c=2 address=0x54
[0001.821] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.825] C> GPIO driver for chip_id 0x2 could not be found
[0001.831] E> cam_eeprom_read: Canât get gpio driver
[0001.835] I> Eeprom read failed 0x4d4d000d
[0001.839] I> Reading eeprom i2c=2 address=0x57
[0001.844] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.848] C> GPIO driver for chip_id 0x2 could not be found
[0001.854] E> cam_eeprom_read: Canât get gpio driver
[0001.858] I> Eeprom read failed 0x4d4d000d
[0001.862] I> create_pm_ids: id: 3489-0888-300-J, len: 15
[0001.867] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.878] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0001.883] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.902] E> cannot find any other nvdisp nodes
[0001.906] E> no valid display unit config found in dtb
[0001.912] W> display init failed
[0001.915] initializing target
[0001.918] calling apps_init()
[0001.921] starting app kernel_boot_app
[0001.944] I> found decompressor handler: lz4-legacy
[0001.948] I> decompressing BMP blob âŠ
[0001.958] I> Kernel type = Normal
[0001.962] I> Loading kernel-bootctrl from partition
[0001.966] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0001.980] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0001.987] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.994] I> ########## Fixed storage boot ##########
[0001.999] W> No valid slot number is found in scratch register
[0002.005] W> Return default slot: _a
[0002.008] I> A/B: bin_type (24) slot 0
[0002.024] I> Boot image size read from image header: 75402
[0002.029] I> Boot image load address: 0x80400000
[0002.033] I> Loading kernel from partition
[0002.037] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.981] I> Validate kernel âŠ
[0002.984] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0002.991] I> kernel-dtb is already loaded
[0002.995] I> Validate kernel-dtb âŠ
[0002.998] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.006] I> Checking boot.img header magic ⊠[0003.010] I> [OK]
[0003.012] I> Kernel hdr @0x80400000
[0003.015] I> Kernel dtb @0x80000000
[0003.018] I> decompressor handler not found
[0003.022] I> Copying kernel image (480258 bytes) from 0x80400800 to 0x80600000 ⊠[0003.030] I> Done
[0003.032] I> Move ramdisk (len: 0) from 0x80476000 to 0x947b0000
[0003.039] I> Updated bpmp info to DTB
[0003.044] I> Ramdisk: Base: 0x947b0000; Size: 0x0
[0003.048] I> Updated initrd info to DTB
[0003.052] W> WARN: Fail to override âconsole=noneâ in commandline
[0003.058] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.065] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.072] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.079] I> disabled_core_mask: 0xffffff0c
[0003.083] W> No valid slot number is found in scratch register
[0003.089] W> Return default slot: _a
[0003.092] I> Active slot suffix:
[0003.095] I> add_boot_slot_suffix: slot_suffix =
[0003.100] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwai
[0003.145] I> Updated bootarg info to DTB
[0003.149] W> MAC addr invalid!
[0003.152] E> Failed to get WIFI MAC address
[0003.156] W> MAC addr invalid!
[0003.158] E> Failed to get Bluetooth MAC address
[0003.163] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cc:42:f0
[0003.169] E> Found no plugin manager ids in source DT
[0003.174] W> Add plugin manager ids from board info
[0003.179] W> âplugin-managerâ doesnât exist, creating
[0003.184] W> âidsâ doesnât exist, creating
[0003.188] W> âconnectionâ doesnât exist, creating
[0003.192] W> âconfigsâ doesnât exist, creating
[0003.196] I> create_pm_ids: id: 3489-0888-300-J, len: 15
[0003.202] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.212] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0003.218] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0003.229] I> Adding plugin-manager/ids/3489-0888-300=/i2c@c250000:module@0x50
[0003.236] W> âi2c@c250000â doesnât exist, creating
[0003.240] W> âmodule@0x50â doesnât exist, creating
[0003.245] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x50
[0003.252] W> âi2c@3160000â doesnât exist, creating
[0003.257] W> âmodule@0x50â doesnât exist, creating
[0003.263] I> Adding plugin-manager/ids/3489-0888-300-J
[0003.269] I> Adding plugin-manager/configs/3489-mem-type 00
[0003.275] I> Adding plugin-manager/configs/3489-power-config 00
[0003.281] I> Adding plugin-manager/configs/3489-misc-config 00
[0003.287] I> Adding plugin-manager/configs/3489-modem-config 00
[0003.293] I> Adding plugin-manager/configs/3489-touch-config 00
[0003.298] I> Adding plugin-manager/configs/3489-display-config 00
[0003.305] I> Adding plugin-manager/cvm
[0003.308] W> âchip-idâ doesnât exist, creating
[0003.313] I> Adding plugin-manager/chip-id/A02P
[0003.317] W> âodm-dataâ doesnât exist, creating
[0003.322] I> Adding /chosen/plugin-manager/odm-data
[0003.330] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.336] I> added [base:0xf0200000, size:0x85600000] to /memory
[0003.342] I> added [base:0x175e00000, size:0x200000] to /memory
[0003.348] I> added [base:0x176600000, size:0x200000] to /memory
[0003.353] I> added [base:0x177000000, size:0x200000] to /memory
[0003.359] I> Updated memory info to DTB
[0003.363] E> add_disp_param: failed to get display params for du=0
[0003.371] W> âresetâ doesnât exist, creating
[0003.375] W> âpmc-reset-reasonâ doesnât exist, creating
[0003.380] W> âpmic-reset-reasonâ doesnât exist, creating
[0003.386] I> Adding ecid(00000001645cc4002000000005058380) to DT
[0003.392] I> disabled_core_mask: 0xffffff0c
[0003.402] I> Add serial number:1422419138473 as DT property
[0003.409] I> Plugin-manager override starting
[0003.415] I> node /plugin-manager/fragement@0 matches
[0003.423] I> node /plugin-manager/fragement@4 matches
[0003.447] I> Disable plugin-manager status in FDT
[0003.452] I> Plugin-manager override finished successfully
[0003.457] I> tegrabl_load_kernel_and_dtb: Done
[0003.462] E> tegrabl_display_clear: display is not initialized
[0003.467] W> Boot logo display failedâŠ
[0003.471] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2016.07 (Jan 21 2021 - 12:42:34 +0530)Version:1.3.0.0
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 3.8 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Writing to MMC(0)⊠done
BOOT_REASON:SW_REBOOT
TESt:BOOT_REASON:SW_REBOOT
Hit any key to stop autoboot: 0
Retrieving file: /boot/extlinux/extlinux_pri.conf
350 bytes read in 154 ms (2 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565615 bytes read in 270 ms (19.7 MiB/s)
Retrieving file: /boot/Image
34267144 bytes read in 855 ms (38.2 MiB/s)
append: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 con
Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 0000000080042f48
