I was wondering if it was possible to use a 4pin y fan splitter to use two 4pin pwm fans on the one port in the jetson.
Thanks in advance.
Thanks in advance.
Yes, it’s feasible to use two 5V PWM fans. The concern is Pin 3 (FAN_TACH). It can only support one FAN. You can cut off other unused FAN_TACH signal on Fan Splitter.
