Output below_
$sudo /usr/sbin/nvpmodel -q
NVPM WARN: fan mode is not set!
NV Power Mode: MAXN
0
Below is from tegrastats.
First lines before application is run. After line 14 application is started.
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25.5C PMIC@100C GPU@24.5C AO@31C thermal@25C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25.5C PMIC@100C GPU@24C AO@31C thermal@25C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [1%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25.5C PMIC@100C GPU@24C AO@31C thermal@25C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25C PMIC@100C GPU@24C AO@31C thermal@24.75C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@24C AO@31C thermal@24.5C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,1%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25C PMIC@100C GPU@24C AO@31C thermal@24.75C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,1%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25C PMIC@100C GPU@24C AO@30.5C thermal@24.25C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.5C
RAM 868/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.75C
RAM 868/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [4%@1479,3%@1479,1%@1479,2%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.75C
RAM 868/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,0%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@21.5C CPU@25C PMIC@100C GPU@24C AO@30.5C thermal@24.5C
RAM 873/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [0%@1479,0%@1479,0%@1479,11%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@25.5C PMIC@100C GPU@23.5C AO@30.5C thermal@24.75C
RAM 906/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,13%@1479,14%@1479,94%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@23C CPU@25.5C PMIC@100C GPU@24C AO@31C thermal@24.75C
RAM 1067/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [50%@1479,7%@1479,50%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 1% PLL@22.5C CPU@25.5C PMIC@100C GPU@24C AO@31C thermal@25.25C
RAM 1204/3964MB (lfb 317x4MB) SWAP 0/1982MB (cached 0MB) CPU [7%@1479,79%@1479,20%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 3% PLL@22.5C CPU@26C PMIC@100C GPU@24C AO@31C thermal@25C
RAM 1358/3964MB (lfb 316x4MB) SWAP 0/1982MB (cached 0MB) CPU [7%@1479,98%@1479,8%@1479,5%@1479] EMC_FREQ 0% GR3D_FREQ 4% PLL@22.5C CPU@26.5C PMIC@100C GPU@24C AO@31C thermal@25.25C
RAM 1490/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [11%@1479,95%@1479,9%@1479,7%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@23C CPU@26.5C PMIC@100C GPU@23.5C AO@31C thermal@25.25C
RAM 1501/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [9%@1479,40%@1479,6%@1479,6%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25.5C PMIC@100C GPU@24C AO@30.5C thermal@24.5C
RAM 1502/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [4%@1479,3%@1479,2%@1479,1%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.25C
RAM 1503/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [3%@1479,3%@1479,3%@1479,3%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@24C AO@30.5C thermal@24.25C
RAM 1502/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [11%@1479,20%@1479,7%@1479,9%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.75C
RAM 1503/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [1%@1479,4%@1479,0%@1479,2%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.25C
RAM 1501/3964MB (lfb 312x4MB) SWAP 0/1982MB (cached 0MB) CPU [1%@1479,6%@1479,1%@1479,3%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22C CPU@25C PMIC@100C GPU@23.5C AO@30.5C thermal@24.25C
RAM 1546/3964MB (lfb 311x4MB) SWAP 0/1982MB (cached 0MB) CPU [18%@1479,13%@1479,22%@1479,11%@1479] EMC_FREQ 0% GR3D_FREQ 50% PLL@22.5C CPU@27C PMIC@100C GPU@24.5C AO@33.5C thermal@24.5C
RAM 1549/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [18%@1479,29%@1479,16%@1479,17%@1479] EMC_FREQ 0% GR3D_FREQ 0% PLL@22.5C CPU@26.5C PMIC@100C GPU@24.5C AO@31C thermal@25C
RAM 1554/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [58%@1479,45%@1479,38%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 91% PLL@22.5C CPU@28C PMIC@100C GPU@25C AO@33.5C thermal@25.25C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [43%@1479,42%@1479,38%@1479,38%@1479] EMC_FREQ 0% GR3D_FREQ 64% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@33C thermal@26.5C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [27%@1479,32%@1479,29%@1479,34%@1479] EMC_FREQ 0% GR3D_FREQ 49% PLL@23C CPU@28C PMIC@100C GPU@25.5C AO@33C thermal@26.75C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [18%@1479,21%@1479,17%@1479,40%@1479] EMC_FREQ 0% GR3D_FREQ 87% PLL@23C CPU@28C PMIC@100C GPU@25C AO@33.5C thermal@26.75C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [13%@1479,30%@1479,14%@1479,22%@1479] EMC_FREQ 0% GR3D_FREQ 75% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@26.5C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [11%@1479,29%@1479,16%@1479,20%@1479] EMC_FREQ 0% GR3D_FREQ 99% PLL@23C CPU@28C PMIC@100C GPU@25.5C AO@34C thermal@26.5C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,14%@1479,13%@1479,28%@1479] EMC_FREQ 0% GR3D_FREQ 92% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@26.25C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,23%@1479,24%@1479,14%@1479] EMC_FREQ 0% GR3D_FREQ 99% PLL@23.5C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@26.5C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,22%@1479,19%@1479,17%@1479] EMC_FREQ 0% GR3D_FREQ 88% PLL@23.5C CPU@28C PMIC@100C GPU@25.5C AO@34C thermal@26.5C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [13%@1479,22%@1479,10%@1479,27%@1479] EMC_FREQ 0% GR3D_FREQ 99% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@34C thermal@26.75C
RAM 1552/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [11%@1479,26%@1479,9%@1479,30%@1479] EMC_FREQ 0% GR3D_FREQ 87% PLL@23.5C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@26.75C
RAM 1551/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,16%@1479,18%@1479,18%@1479] EMC_FREQ 0% GR3D_FREQ 97% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@34C thermal@26.75C
RAM 1551/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [14%@1479,21%@1479,15%@1479,29%@1479] EMC_FREQ 0% GR3D_FREQ 56% PLL@23C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@26.75C
RAM 1551/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [12%@1479,20%@1479,22%@1479,18%@1479] EMC_FREQ 0% GR3D_FREQ 64% PLL@23.5C CPU@28C PMIC@100C GPU@25.5C AO@33.5C thermal@26.5C
RAM 1551/3964MB (lfb 310x4MB) SWAP 0/1982MB (cached 0MB) CPU [10%@1479,16%@1479,13%@1479,21%@1479] EMC_FREQ 0% GR3D_FREQ 34% PLL@23.5C CPU@28.5C PMIC@100C GPU@25.5C AO@33C thermal@26.25C
RAM 1551/3964MB (lfb 308x4MB) SWAP 0/1982MB (cached 0MB) CPU [22%@1479,23%@1479,22%@1479,23%@1479] EMC_FREQ 0% GR3D_FREQ 47% PLL@23C CPU@28C PMIC@100C GPU@26C AO@33.5C thermal@26.75C
RAM 1551/3964MB (lfb 308x4MB) SWAP 0/1982MB (cached 0MB) CPU [15%@1479,13%@1479,19%@1479,21%@1479] EMC_FREQ 0% GR3D_FREQ 54% PLL@23.5C CPU@28.5C PMIC@100C GPU@25.5C AO@33C thermal@26.5C
RAM 1551/3964MB (lfb 308x4MB) SWAP 0/1982MB (cached 0MB) CPU [14%@1479,24%@1479,12%@1479,29%@1479] EMC_FREQ 0% GR3D_FREQ 35% PLL@23.5C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@27C
RAM 1551/3964MB (lfb 308x4MB) SWAP 0/1982MB (cached 0MB) CPU [16%@1479,20%@1479,13%@1479,26%@1479] EMC_FREQ 0% GR3D_FREQ 51% PLL@23.5C CPU@28.5C PMIC@100C GPU@25.5C AO@33.5C thermal@27C
RAM 1551/3964MB (lfb 308x4MB) SWAP 0/1982MB (cached 0MB) CPU [17%@1479,15%@1479,18%@1479,23%@1479] EMC_FREQ 0% GR3D_FREQ 35% PLL@23.5C CPU@27.5C PMIC@100C GPU@25.5C AO@33.5C thermal@27C
