Hello, everyone:
I used NX output PWM to fan, the same config as the original carrier board. tegra_pwm6
GPIO14(PH.01), but when i used the command cat /sys/kernel/debug/pwm
, it show
platform/32d0000.pwm, 1 PWM device
pwm-0 (pwm-fan ): requested enabled period: 45334 ns duty: 0 ns polarity: normal
and the sound of the fan is very large.
So what should i do next? thank you.
best reagrds,
ultwcz1997
hello ultwcz1997,
may I know which JetPack release version you’re working with,
are you running heavy loaded program?
what’s the thermal condition, please also enable $ sudo tegrastats
to gather processor reports.
besides, could you please refer to developer guide for Fan Speed Control.
thanks
Hi, JerryChang,
Thank you reply. I am so sorry to reply slowly.
1.may I know which JetPack release version you’re working with?
Jepack4.4 R32.4.3
2.are you running heavily loaded program?
maybe, i will try to disable some processes.
3. $ sudo tegrastats
RAM 3682/7771MB (lfb 884x4MB) SWAP 0/3886MB (cached 0MB) CPU [22%@1420,26%@1420,25%@1420,26%@1420,26%@1420,30%@1420] EMC_FREQ 9%@1600 GR3D_FREQ 78%@1109 APE 150 MTS fg 0% bg 15% AO@27C GPU@29C PMIC@100C AUX@28C CPU@30C thermal@28.75C VDD_IN 6560/6560 VDD_CPU_GPU_CV 2640/2640 VDD_SOC 1357/1357
RAM 3683/7771MB (lfb 884x4MB) SWAP 0/3886MB (cached 0MB) CPU [25%@1420,25%@1420,21%@1420,24%@1420,25%@1420,25%@1420] EMC_FREQ 9%@1600 GR3D_FREQ 0%@1109 APE 150 MTS fg 0% bg 12% AO@27C GPU@29C PMIC@100C AUX@28C CPU@29.5C thermal@28.75C VDD_IN 6400/6480 VDD_CPU_GPU_CV 2520/2580 VDD_SOC 1317/1337
RAM 3683/7771MB (lfb 884x4MB) SWAP 0/3886MB (cached 0MB) CPU [23%@1420,21%@1420,26%@1420,28%@1420,27%@1420,22%@1420] EMC_FREQ 9%@1600 GR3D_FREQ 0%@1109 APE 150 MTS fg 0% bg 13% AO@27C GPU@29C PMIC@100C AUX@28C CPU@29.5C thermal@28.95C VDD_IN 6360/6440 VDD_CPU_GPU_CV 2480/2546 VDD_SOC 1317/1330
RAM 3684/7771MB (lfb 884x4MB) SWAP 0/3886MB (cached 0MB) CPU [25%@1420,25%@1420,27%@1420,21%@1420,23%@1420,27%@1420] EMC_FREQ 9%@1600 GR3D_FREQ 0%@1109 APE 150 MTS fg 0% bg 14% AO@27C GPU@29C PMIC@100C AUX@28C CPU@29.5C thermal@28.75C VDD_IN 6320/6410 VDD_CPU_GPU_CV 2480/2530 VDD_SOC 1317/1327
The main problem is the sound of the fan is large when i boot at first.
hello ultwcz1997,
fan is setting to full speed while system boot-up, it should behavior normally after you enter ubuntu desktop.
you may see-also Maximizing Jetson Nano or Jetson TX1 Performance, if you running jetson_clocks
script to maximize Jetson Nano performance by adding --fan
options. it’ll also set the maximum PWM fan speed.
