In fact, When I run the script I do have an output that might look like PWM from very far away but that is absolutely not suitable for servos.
Here is the output on an oscilloscope : https://imgur.com/a/Xb6tlPg and the “rectangles” that you can see on top of the signal, do look like a PWM output as they have the right duty cycle that I provided and the right frequency of 50 Hz but I can’t do anything with it…
My oscillo is wired between one ground pin of the header and the 33 pin (it is the same with the 32 pin)
Do any of you have any idea of what I am doing wrong ?
Thank you for your answer. I tried a few days back this method using the same tutorial as the one you sent me but I only managed to break the card and I had to reflash it make it works again (it wouldn’t boot after the reconfiguring).
As such, I wanted to try a different approach and the doc says to use the jetson-io.py script to configure the GPIO, here is its output https://imgur.com/a/guWko1W. Isn’t this sufficient ?
yes, we had release Jetson-IO python script since l4t-r32.3.1, Jetpack-4.3
you’re able to configure 40-pin pinout of Nano J41 with that script file.
thanks
Yes, I managed to fix the issue but it was more a workaround than a fix. I needed 2 PWM outputs to control 2 motors and as I couldn’t manage to get any of the integrated ones to work, I used a PCA9685 board which allow to use 16 PWM outputs from one I2C interface of the Jetson Nano which worked perfectly fine with python.
If you have any more questions I’ll gladly answer them ! And if you have an idea of how I could have fixed the issue, I’m curious. I don’t have a board with me anymore though…
