PWM on Jetson Nano with Jetpack 4.3
I am trying to get PWM working on my Jetson Nano under Jetpack 4.3. I am using physical pin 33, and grounded through physical pin 9. In running the NVIDIA sample code found here:
I get no errors, but on the scope, I see no indication of PWM.
I then tried this very simple example from the python3 shell:
sudo python3
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(33,GPIO.OUT)
my_pwm=GPIO.PWM(33,100)
my_pwm.start(50)
Again, no errors, but no PWM on the scope and no voltage on a volt meter.
Any help would be greatly appreciated.
Paul McWhorter
toptechboy.com
hello paul.mcwhorter,
according to Nano’s pinmux spreadsheets, pin-33 (GPIO_PE6) has configure as GPIO pin by default.
please refer to documentation, Configuring the 40-Pin Expansion Header chapter to update board configuration for pin customization.
thanks
You need to enable the PWM pins on Jetson Nano before running the program.
Open a terminal and type the following;
Enable Pin 33 / PWM2
sudo busybox devmem 0x70003248 32 0x46
sudo busybox devmem 0x6000d100 32 0x00
make sure to install busybox library if not installed.
busybox: sudo apt-get install busybox
Running the GPIO configuration program was indeed the solution. I now have pwm working. Thank you.
Hi @paul.mcwhorter,
Thank you for the post. I am just wondering that (for the power sources) did you connect 3.3V or 5V?
Hİ!
I want to spin servo 180 degrees. How can I do this? This code has not sudo codes for val = 25,incr = 5.
