PWM works on pin 33 but not pin 32 on Dev Kit
I have trouble getting PWM output on Pin 32 on the Xavier NX dev kit.
I configured the Pin 32 and Pin 33 with /opt/nvidia/jetson-io/jetson-io.py
Pin 33 works as expected using the jetson-gpio library.
But Pin 32 seems half on and sometimes on in an erractic pattern. Also when checking the jetson-io.py tool, the Pin sometimes says “gp” instead of “pwm8”.
Udev rules are configured according to the documentation in jetson-gpio.
Any hints on how to get Pin 32 working with PWM?
hello robo_chris82,
please refer to Jetson Xavier NX GPIO Header J12 PINOUT.
you should also check pinmux spreadsheets, pin-32 is by default configure as GPIO pin, please also refer to pinmux changes to configure pin32 as PWM pin,
thanks
Are you saying that the provided jetson-io.py tool does not work for Pin 32 on the NX, just for Pin 33?
Pin 33 is also is by default a GPIO pin, and the jetson-io.py tool created a .dtb file that worked just fine to enable PWM on Pin 33.
hello robo_chris82,
you may check the board configuration files, could you please share the results of pinmux.0x0243d030=.
BTW, according to Topic 121192, PWM is works by updated pinmux table on Xavier NX.
