Pwm控制器
官方你好,我想通过pwm控制风扇
现在我在设备树节新增了两个gpio个节点,想把他们复用为pwm输出,现在我在linux系统中找不到控制他们输出的地方,soc_gpio37_pr0 可以在/sys/class/pwm/pwmchip3中控制,但这个是我一个一个试出来的,现在我找不到soc_gpio21_ph0 的控制节点,
pinmux@2430000 {
		compatible = "nvidia,tegra234-pinmux";
		reg = <0x00 0x2430000 0x00 0x19100 0x00 0xc300000 0x00 0x4000>;
		#gpio-range-cells = <0x03>;
		status = "okay";
		phandle = <0x2e5>;
		soc_gpio37_pr0 {
    		nvidia,pins = "soc_gpio37_pr0";
			nvidia,function = "gp";
    		nvidia,pull = <0x00>;
    		nvidia,tristate = <0x01>;
    		nvidia,enable-input = <0x01>;
    		nvidia,io-high-voltage = <0x01>;
    		nvidia,lpdr = <0x00>;
		soc_gpio21_ph0 {
			nvidia,pins = "soc_gpio21_ph0";
			nvidia,function = "rsvd0";
		pex_rst_c5_in {
			phandle = <0x2c>;
			pex_rst {
				nvidia,pins = "pex_l5_rst_n_paf1";
				nvidia,function = "rsvd1";
Hi 1132492539,
There should be sysfs node available for your use case.
Please share the result of the following command on your board.
$ ls -l /sys/class/hwmon/
您好,我现在使用的是AGX Orin的定制板
版本:Jetson Linux 35.2.1
现在我有4个风扇接口,可以通过/sys/class/hwmon/hwmon4控制一个,通过/sys/class/pwm/pwmchip3控制一个,还有两个找不到对应关系,分别是gpio433(PN.01)和gpio391(PH.00)
test@tegra-ubuntu:~$ ls -l /sys/class/hwmon/
total 0
lrwxrwxrwx 1 root root 0 Sep  8  2022 hwmon0 -> ../../devices/platform/39c0000.tachometer/hwmon/hwmon0
lrwxrwxrwx 1 root root 0 Sep  8  2022 hwmon1 -> ../../devices/platform/soctherm-oc-event/hwmon/hwmon1
lrwxrwxrwx 1 root root 0 Jan 24 08:14 hwmon2 -> ../../devices/platform/c240000.i2c/i2c-1/1-0040/hwmon/hwmon2
lrwxrwxrwx 1 root root 0 Jan 24 08:14 hwmon3 -> ../../devices/platform/c240000.i2c/i2c-1/1-0041/hwmon/hwmon3
lrwxrwxrwx 1 root root 0 Jan 24 08:14 hwmon4 -> ../../devices/platform/pwm-fan/hwmon/hwmon4
lrwxrwxrwx 1 root root 0 Jan 24 08:14 hwmon5 -> ../../devices/platform/6810000.ethernet/mdio_bus/6810000.ethernet/6810000.ethernet:00/hwmon/hwmon5
lrwxrwxrwx 1 root root 0 Jan 24 08:14 hwmon6 -> ../../devices/platform/6910000.ethernet/mdio_bus/6910000.ethernet/6910000.ethernet:00/hwmon/hwmon6
如果你使用的是Custom carrier board for AGX Orin, 我們這邊不知道你板子的設計是如何的
hwmon4是預設enable可以用來控制風扇轉速的
看起來你的板子上有另外三個風扇也要透過PWM來控制
PN.01:
PH.00:
以上兩根pin看起來都從40-expansion header上接出來的
你必須先從pinmux spreadsheet上將"Customer Usage"那欄改為GP_PWM*
