I install official SDK Manager Beta 0.9.9.2351, and flash the PX2 device, but after finish, PX2 can’t boot up ubuntu, here is the log:
starting app bpmp_incoming
�[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.80-rt61-tegra (buildbrain@mobile-u64-3039) (gcc version 4.9.4 20150629 (prerelease) (Linaro GCC 4.9-2015.06) ) #1 SMP PREEMPT RT Tue Sep 4 11:02:44 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7fe00000
[ 0.000000] OF: fdt: - 100000000 , 15a000000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003110000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node generic_carveout, compatible id nvidia,generic_carveout
[ 0.000000] cma: Reserved 256 MiB at 0x00000000afc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1d9e27000 s56448 r8192 d29568 u94208
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1652112
[ 0.000000] Kernel command line: fbcon=map:0 console=tty0 root=/dev/mmcblk0p3 earlycon=uart8250,mmio32,0x03110000 console=ttyS0,115200n8 no_console_suspend=1 tegra_keep_boot_clocks cma=268435456 tegraid=18.1.2.0.0 ratchet_status=0x0 uid=1642d98421c00000012038400 bl_debug_data=65536@0xf81cb0000 earlycon=uart8250,mmio32,0x03110000 bl_prof_dataptr=65536@0xf81cc0000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6282932K/6713344K available (12350K kernel code, 2284K rwdata, 5228K rodata, 5376K init, 862K bss, 168268K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c90000 ( 12352 KB)
[ 0.000000] .rodata : 0xffffff8008c90000 - 0xffffff80091b0000 ( 5248 KB)
[ 0.000000] .init : 0xffffff80091b0000 - 0xffffff80096f0000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80096f0000 - 0xffffff800992b008 ( 2285 KB)
[ 0.000000] .bss : 0xffffff800992b008 - 0xffffff8009a029a8 ( 863 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07680000 ( 118 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1da000000 ( 7584 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000199] Console: colour dummy device 80x25
[ 0.062407] console [tty0] enabled
[ 0.062412] kmemleak: Kernel memory leak detector disabled
[ 0.062420] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.062422] pid_max: default: 32768 minimum: 301
[ 0.062481] Security Framework initialized
[ 0.062504] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.062507] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.064466] sched-energy: Sched-energy-costs installed from DT
[ 0.072433] ASID allocator initialised with 65536 entries
[ 0.122801] tegra-id: chipid=21817.
[ 0.123399] tegra-id: opt_subrevision=1.
[ 0.124077] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.125243] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-safety-vm.dts
[ 0.128434] DTB Build time: Sep 4 2018 17:59:36
[ 0.189022] CPU1: Booted secondary processor [4e0f0030]
[ 0.189051] CPU1: CPU online now.
[ 0.232998] CPU2: Booted secondary processor [4e0f0030]
[ 0.233021] CPU2: CPU online now.
[ 0.276871] CPU3: Booted secondary processor [411fd073]
[ 0.276889] CPU3: CPU online now.
[ 0.320993] CPU4: Booted secondary processor [411fd073]
[ 0.321006] CPU4: CPU online now.
[ 0.365113] CPU5: Booted secondary processor [411fd073]
[ 0.365131] CPU5: CPU online now.
[ 0.366632] Brought up 6 CPUs
[ 0.367136] SMP: Total of 6 processors activated.
[ 0.367928] CPU features: detected feature: 32-bit EL0 Support
[ 0.369234] CPU: All CPU(s) started at EL1
[ 0.369963] alternatives: patching kernel code
[ 0.371177] devtmpfs: initialized
[ 0.385247] Initilizing CustomIPI irq domain
[ 0.386132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.387780] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.391132] pinctrl core: initialized pinctrl subsystem
[ 0.392317] regulator-dummy: no parameters
[ 0.393183] Initializing plugin-manager
[ 0.393880] Plugin module not found
[ 0.395896] tegra_hv: adding ivc99: rx_base=ffffff8009b00000 tx_base = ffffff8009b00180 size=180 irq = 5 (386)
[ 0.397621] tegra_hv: added ivc99
[ 0.398214] tegra_hv: adding ivc13: rx_base=ffffff8009b10000 tx_base = ffffff8009b10100 size=100 irq = 6 (387)
[ 0.399875] tegra_hv: added ivc13
[ 0.400458] tegra_hv: adding ivc12: rx_base=ffffff8009b20000 tx_base = ffffff8009b20100 size=100 irq = 7 (388)
[ 0.402134] tegra_hv: added ivc12
[ 0.402709] tegra_hv: adding ivc11: rx_base=ffffff8009b30000 tx_base = ffffff8009b30100 size=100 irq = 8 (389)
[ 0.404373] tegra_hv: added ivc11
[ 0.404946] tegra_hv: adding ivc10: rx_base=ffffff8009b40000 tx_base = ffffff8009b40100 size=100 irq = 9 (390)
[ 0.406618] tegra_hv: added ivc10
[ 0.407197] tegra_hv: adding ivc9: rx_base=ffffff8009b50000 tx_base = ffffff8009b50100 size=100 irq = 10 (391)
[ 0.408854] tegra_hv: added ivc9
[ 0.409435] tegra_hv: adding ivc8: rx_base=ffffff8009b60000 tx_base = ffffff8009b60100 size=100 irq = 11 (392)
[ 0.411094] tegra_hv: added ivc8
[ 0.411655] tegra_hv: adding ivc7: rx_base=ffffff8009b70000 tx_base = ffffff8009b70100 size=100 irq = 12 (393)
[ 0.413331] tegra_hv: added ivc7
[ 0.413897] tegra_hv: adding ivc6: rx_base=ffffff8009b80000 tx_base = ffffff8009b80100 size=100 irq = 13 (394)
[ 0.415553] tegra_hv: added ivc6
[ 0.416119] tegra_hv: adding ivc5: rx_base=ffffff8009b90000 tx_base = ffffff8009b90100 size=100 irq = 14 (395)
[ 0.417791] tegra_hv: added ivc5
[ 0.418354] tegra_hv: adding ivc4: rx_base=ffffff8009ba0000 tx_base = ffffff8009ba0100 size=100 irq = 15 (396)
[ 0.420017] tegra_hv: added ivc4
[ 0.420577] tegra_hv: adding ivc3: rx_base=ffffff8009bb0000 tx_base = ffffff8009bb0100 size=100 irq = 16 (397)
[ 0.422252] tegra_hv: added ivc3
[ 0.422810] tegra_hv: adding ivc2: rx_base=ffffff8009bc0000 tx_base = ffffff8009bc0100 size=100 irq = 17 (398)
[ 0.424472] tegra_hv: added ivc2
[ 0.425031] tegra_hv: adding ivc1: rx_base=ffffff8009bd0000 tx_base = ffffff8009bd0100 size=100 irq = 18 (399)
[ 0.426707] tegra_hv: added ivc1
[ 0.427273] tegra_hv: adding ivc0: rx_base=ffffff8009be0000 tx_base = ffffff8009be0100 size=100 irq = 19 (400)
[ 0.428927] tegra_hv: added ivc0
[ 0.429507] tegra_hv: adding ivc101: rx_base=ffffff8009a80000 tx_base = ffffff8009a800c0 size=c0 irq = 20 (401)
[ 0.431183] tegra_hv: added ivc101
[ 0.431776] tegra_hv: adding ivc56: rx_base=ffffff8009a90000 tx_base = ffffff8009a90880 size=880 irq = 21 (402)
[ 0.433468] tegra_hv: added ivc56
[ 0.434045] tegra_hv: adding ivc31: rx_base=ffffff8009aa0000 tx_base = ffffff8009aa0680 size=680 irq = 22 (403)
[ 0.435668] tegra_hv: added ivc31
[ 0.436115] tegra_hv: adding ivc30: rx_base=ffffff8009ab0000 tx_base = ffffff8009ab0480 size=480 irq = 23 (404)
[ 0.437382] tegra_hv: added ivc30
[ 0.437820] tegra_hv: adding ivc29: rx_base=ffffff8009ac0000 tx_base = ffffff8009ac0280 size=280 irq = 24 (405)
[ 0.439065] tegra_hv: added ivc29
[ 0.439499] tegra_hv: adding ivc28: rx_base=ffffff8009ad0000 tx_base = ffffff8009ad0180 size=180 irq = 25 (406)
[ 0.440746] tegra_hv: added ivc28
[ 0.441199] tegra_hv: adding ivc32: rx_base=ffffff8008040000 tx_base = ffffff8008040100 size=100 irq = 26 (407)
[ 0.442445] tegra_hv: added ivc32
[ 0.442880] tegra_hv: adding ivc33: rx_base=ffffff8009a40000 tx_base = ffffff8009a54080 size=14080 irq = 27 (408)
[ 0.444146] tegra_hv: added ivc33
[ 0.444581] tegra_hv: adding ivc102: rx_base=ffffff8008060000 tx_base = ffffff8008060100 size=100 irq = 28 (409)
[ 0.445854] tegra_hv: added ivc102
[ 0.446301] tegra_hv: adding ivc76: rx_base=ffffff8009c00000 tx_base = ffffff8009c0a180 size=a180 irq = 29 (410)
[ 0.447555] tegra_hv: added ivc76
[ 0.447970] tegra_hv: added mempool 0: ipa=f80200000 size=400000 peer=2
[ 0.448786] tegra_hv: added mempool 1: ipa=f80600000 size=800000 peer=2
[ 0.449615] tegra_hv: added mempool 2: ipa=f80e00000 size=10000 peer=2
[ 0.450425] tegra_hv: added mempool 3: ipa=f81000000 size=400000 peer=1
[ 0.451237] tegra_hv: added mempool 5: ipa=f81400000 size=40000 peer=5
[ 0.452045] tegra_hv: added mempool 6: ipa=f81440000 size=10000 peer=3
[ 0.452848] tegra_hv: added mempool 7: ipa=f81450000 size=40000 peer=6
[ 0.453672] tegra_hv: initialized
[ 0.454267] NET: Registered protocol family 16
[ 0.456592] pstore: using zlib compression
[ 0.459459] console [pstore-1] enabled
[ 0.460908] pstore: Registered ramoops as persistent store backend
[ 0.463232] ramoops: attached 0x200000@0xffc00000, ecc: 0/0
[ 0.486633] bpmp: mail init ok
[ 0.490855] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.493312] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.494984] arm-smmu 12000000.iommu: stage 1 translation
[ 0.496804] arm-smmu 12000000.iommu: stream indexing with 128 indices
[ 0.498923] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.502568] arm-smmu 12000000.iommu: 32 context banks (0 stage-2 only)
[ 0.504732] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.512393] vdso: 2 pages (1 code @ ffffff8008c97000, 1 data @ ffffff80096f4000)
[ 0.514906] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.521674] atomic_pool_init():632: DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.525601] Registering BPMP clocks…
[ 0.527027] tegra_bpmp_clk_init: clock init ok (636 clks)
[ 0.529180] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.532781] tegra_powergate_init: DONE
[ 0.534017] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-safety-vm.dts
[ 0.540263] DTB Build time: Sep 4 2018 17:59:36
[ 0.543671] Tegra reboot handler registered.
[ 0.545589] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
[ 0.548055] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.550030] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.552092] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.553967] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.556393] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.558656] iommu: Adding device 3460000.sdhci to group 0
[ 0.561841] iommu: Adding device 3160000.i2c to group 1
[ 0.564138] iommu: Adding device c240000.i2c to group 2
[ 0.566108] iommu: Adding device 3180000.i2c to group 3
[ 0.568147] iommu: Adding device 3190000.i2c to group 4
[ 0.570254] iommu: Adding device 31b0000.i2c to group 5
[ 0.572390] iommu: Adding device 31c0000.i2c to group 6
[ 0.574404] iommu: Adding device c250000.i2c to group 7
[ 0.576457] iommu: Adding device 31e0000.i2c to group 8
[ 0.579582] iommu: Adding device 3210000.spi to group 9
[ 0.581648] iommu: Adding device 3230000.spi to group 10
[ 0.583687] iommu: Adding device 3270000.spi to group 11
[ 0.585886] iommu: Adding device 3110000.serial to group 12
[ 0.588709] iommu: Adding device 2490000.ether_qos to group 13
[ 0.590610] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.593198] iommu: Adding device b040000.sce to group 14
[ 0.596120] iommu: Adding device 13e10000.host1x to group 15
[ 0.598424] iommu: Adding device 13e10000.host1x:ctx0 to group 16
[ 0.600715] iommu: Adding device 13e10000.host1x:ctx1 to group 17
[ 0.602979] iommu: Adding device 13e10000.host1x:ctx2 to group 18
[ 0.605275] iommu: Adding device 13e10000.host1x:ctx3 to group 19
[ 0.607524] iommu: Adding device 13e10000.host1x:ctx4 to group 20
[ 0.609789] iommu: Adding device 13e10000.host1x:ctx5 to group 21
[ 0.611999] iommu: Adding device 13e10000.host1x:ctx6 to group 22
[ 0.614391] iommu: Adding device 13e10000.host1x:ctx7 to group 23
[ 0.616815] iommu: Adding device 150c0000.nvcsi to group 24
[ 0.620964] iommu: Adding device smmu_test to group 25
[ 0.623249] mc: mapped MMIO address: 0xffffff800a210000 → 0x2c10000
[ 0.625311] mc: mapped MMIO address: 0xffffff800a230000 → 0x2c20000
[ 0.627308] mc: mapped MMIO address: 0xffffff800a250000 → 0x2c30000
[ 0.629330] mc: mapped MMIO address: 0xffffff800a270000 → 0x2c40000
[ 0.631315] mc: mapped MMIO address: 0xffffff800a290000 → 0x2c50000
[ 0.633345] tegra-mc 2c10000.mc: No mssnvlink node
[ 0.634855] mc-err: mcerr ops are set to t18x
[ 0.637254] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.639987] iommu: Adding device 3530000.xhci to group 26
[ 0.641836] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.643971] iommu: Adding device 3550000.xudc to group 27
[ 0.645754] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.648173] tegra-reset 5000000.clock: registered 193 resets.
[ 0.650606] iommu: Adding device d000000.bpmp to group 28
[ 0.652619] bpmp d000000.bpmp: Found mempool with id 3
[ 0.654223] bpmp d000000.bpmp: ivm 0x0000000f81000000
[ 0.656053] bpmp: ping status is 0
[ 0.657280] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.662495] bpmp d000000.bpmp: probe ok
[ 0.665919] iommu: Adding device 2600000.dma to group 29
[ 0.670619] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.684163] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.690494] iommu: Adding device 10003000.pcie-controller to group 30
[ 0.692621] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.696319] sys-3v3: 3300 mV
[ 0.697507] sys-5v0: 5000 mV
[ 0.701372] iommu: Adding device 13e20000.host1xb to group 31
[ 0.703591] iommu: Adding device 15600000.isp to group 32
[ 0.879657] iommu: Adding device 15340000.vic to group 33
[ 0.881554] iommu: Adding device 154c0000.nvenc to group 34
[ 0.883550] iommu: Adding device 15480000.nvdec to group 35
[ 0.885587] iommu: Adding device 15380000.nvjpg to group 36
[ 0.887569] iommu: Adding device 15500000.tsec to group 37
[ 0.889484] iommu: Adding device 15100000.tsecb to group 38
[ 0.892418] iommu: Adding device vse@15810000 to group 39
[ 0.894399] iommu: Adding device vse@15820000 to group 40
[ 0.896256] iommu: Adding device vse@15830000 to group 41
[ 0.898083] iommu: Adding device vse@15840000 to group 42
[ 0.910204] max929x_i2c_client_init: called
[ 0.911950] vdd-1v1: Bringing 0uV into 1100000-1100000uV
[ 0.913604] vdd-1v1: 1100 mV
[ 0.914680] vdd-1v2: Bringing 0uV into 1200000-1200000uV
[ 0.916375] vdd-1v2: 1200 mV
[ 0.917432] vdd-1v8-ddr: Bringing 0uV into 1800000-1800000uV
[ 0.919165] vdd-1v8-ddr: 1800 mV
[ 0.920350] vdd-3v3: Bringing 0uV into 3300000-3300000uV
[ 0.921995] vdd-3v3: 3300 mV
[ 0.923036] spmic-sd4: Bringing 0uV into 1100000-1100000uV
[ 0.924760] spmic-sd4: 1100 mV
[ 0.925847] vdd-1v8-pll: Bringing 0uV into 1800000-1800000uV
[ 0.927620] vdd-1v8-pll: 1800 mV
[ 0.928785] spmic-ldo1: Bringing 0uV into 800000-800000uV
[ 0.930445] spmic-ldo1: 800 mV
[ 0.931567] vdd-v3v-ao: Bringing 0uV into 3300000-3300000uV
[ 0.933284] vdd-v3v-ao: 3300 mV
[ 0.934404] en-vdd-rtc: Bringing 0uV into 800000-800000uV
[ 0.936117] en-vdd-rtc: 800 mV
[ 0.937196] vdd-1v8-ao: Bringing 0uV into 1800000-1800000uV
[ 0.938899] vdd-1v8-ao: 1800 mV
[ 0.940046] vdd-1v05: Bringing 0uV into 1050000-1050000uV
[ 0.941706] vdd-1v05: 1050 mV
[ 0.942774] spmic-ldo8: Bringing 0uV into 800000-800000uV
[ 0.944468] spmic-ldo8: 800 mV
[ 0.945615] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.947790] SCSI subsystem initialized
[ 0.949074] usbcore: registered new interface driver usbfs
[ 0.950778] usbcore: registered new interface driver hub
[ 0.952662] usbcore: registered new device driver usb
[ 0.966059] max929x_i2c_probe: returning 0
[ 0.967583] sn65dsi85_dsi2lvds_panel_create_debugfs: dsi2lvds->debugdir = ffffffc1d1069690
[ 0.970106] sn65dsi85_dsi2lvds_panel_create_debugfs: debugfs_create_file returned ffffffc1d1069780
[ 0.972875] sn65dsi85_i2c_probe: returning with err=0
[ 0.976326] max77620 4-003c: PMIC Version OTP:0x4A and ES:0x1
[ 0.979050] max77620 4-003c: Backup battery charging support disabled
[ 0.981819] max77620-sd0: at 1125 mV
[ 0.983684] max77620-sd1: at 1200 mV
[ 0.985535] max77620-sd2: at 1800 mV
[ 0.987393] max77620-sd3: at 3300 mV
[ 0.989295] max77620-sd4: at 600 mV
[ 0.991121] max77620-ldo0: at 1800 mV
[ 0.992856] max77620-ldo1: at 800 mV
[ 0.994542] max77620-ldo2: at 3300 mV
[ 0.996599] i2c i2c-4: deserialize_i2c ret -22
[ 0.997967] i2c i2c-4: — message dump for debugging —
[ 0.999613] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.001228] i2c i2c-4: 29
[ 1.002063] i2c i2c-4: f2
[ 1.002897] i2c i2c-4:
[ 1.003664] max77620-pmic max20024-pmic: Regulator 8 mode set failed: -22
[ 1.005764] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo3
[ 1.008612] max77620-ldo3: at 3300 mV
[ 1.010349] max77620-ldo4: at 800 mV
[ 1.012290] i2c i2c-4: deserialize_i2c ret -22
[ 1.013668] i2c i2c-4: — message dump for debugging —
[ 1.015309] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.190617] i2c i2c-4: 2d
[ 1.191450] i2c i2c-4: f2
[ 1.192269] i2c i2c-4:
[ 1.193068] max77620-pmic max20024-pmic: Regulator 10 mode set failed: -22
[ 1.195135] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo5
[ 1.198033] max77620-ldo5: at 3300 mV
[ 1.199871] max77620-ldo6: at 1800 mV
[ 1.201693] max77620-ldo7: at 1000 mV
[ 1.203434] max77620-ldo8: at 800 mV
[ 1.205182] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 1.209910] i2c i2c-4: deserialize_i2c ret -22
[ 1.211266] i2c i2c-4: — message dump for debugging —
[ 1.212941] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.214476] i2c i2c-4: 0d
[ 1.215306] i2c i2c-4: ef
[ 1.216140] i2c i2c-4:
[ 1.216928] max77620 4-003c: Failed to sync masks in d
[ 1.218842] max77620 4-003c: max77620 probe successful
[ 1.220691] media: Linux media interface: v0.10
[ 1.222152] Linux video capture interface: v2.00
[ 1.225632] pps_core: LinuxPPS API ver. 1 registered
[ 1.227142] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.229964] PTP clock support registered
[ 1.232714] trusty trusty: trusty version: Built: 10:50:36 Sep 4 2018
[ 1.234900] trusty trusty: selected api version: 3 (requested 3)
[ 1.239168] tegra_hv_wdt tegra_hv_wdt: id=32 irq=26 peer=3 num=1 size=128
[ 1.239334] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
[ 1.244830] vdd-1v8: supplied by vdd-1v8-ddr
[ 1.246295] vdd-1v8: 1800 mV
[ 1.247509] vdd-rtc: supplied by en-vdd-rtc
[ 1.248794] vdd-rtc: at 800 mV
[ 1.250277] vdd-usb2-5v: supplied by vdd-1v8
[ 1.251620] vdd-usb2-5v: 5000 mV
[ 1.362306] mxm-pwr-gpio-1: 5000 mV
[ 1.364200] mxm-pwr_en: supplied by mxm-pwr-gpio-1
[ 1.474230] mxm-pwr_en: 5000 mV
[ 1.477336] random: fast init done
[ 1.478876] camchar: rtcpu character device driver loaded
[ 1.481313] clocksource: Switched to clocksource arch_sys_counter
[ 1.511448] VFS: Disk quotas dquot_6.6.0
[ 1.512745] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.514976] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.517472] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000bfc00000,1073741824
[ 1.518720] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
[ 1.519788] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 1.520594] nvmap_page_pool_init: Total RAM pages: 1636269
[ 1.521273] nvmap_page_pool_init: nvmap page pool size: 204533 pages (798 MB)
[ 1.522214] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.522647] misc nvmap: created heap generic-0 base 0x00000000bfc00000 size (1048576KiB)
[ 1.524983] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 1.532916] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 1.534091] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 1.535197] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 1.536294] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 1.537551] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 1.538674] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tj-therm
[ 1.539791] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.540957] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type Tegra_tx
[ 1.542101] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type Tegra_rx
[ 1.543489] la/ptsa driver initialized.
[ 1.543971] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 1.544718] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[ 1.545614] NET: Registered protocol family 2
[ 1.546498] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.547586] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 1.549408] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.550298] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 1.551193] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 1.552285] NET: Registered protocol family 1
[ 1.553551] RPC: Registered named UNIX socket transport module.
[ 1.555366] RPC: Registered udp transport module.
[ 1.556776] RPC: Registered tcp transport module.
[ 1.558236] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.560314] Unpacking initramfs…
[ 1.576120] Freeing initrd memory: 4768K
[ 1.591406] host1x 13e10000.host1x: initialized
[ 1.604453] host1x 13e20000.host1xb: initialized
[ 1.607397] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.610351] audit: initializing netlink subsys (disabled)
[ 1.612019] audit: type=2000 audit(1.604:1): initialized
[ 1.614260] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.621088] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.623753] NFS: Registering the id_resolver key type
[ 1.625401] Key type id_resolver registered
[ 1.626677] Key type id_legacy registered
[ 1.627900] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.630001] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.631736] fuse init (API version 7.26)
[ 1.638504] NET: Registered protocol family 38
[ 1.639966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.642282] io scheduler noop registered (default)
[ 1.643730] io scheduler deadline registered
[ 1.645229] io scheduler cfq registered
[ 1.649082] iommu: Adding device 2993000.rtcpu to group 43
[ 1.652093] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.666065] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.671008] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.675092] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.677950] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.681000] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=2090250, vi_iso_bw=2577095, max_bw=2577095
[ 1.686783] tsec 15500000.tsec: initialized
[ 1.689504] tsec 15100000.tsecb: initialized
[ 1.697734] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.702682] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.707537] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.712271] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.716925] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.721735] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.726348] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.730999] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.735229] vhost-client 15340000.vic: initialized
[ 1.737781] vhost-client 154c0000.nvenc: initialized
[ 1.741647] vhost-client 15480000.nvdec: initialized
[ 1.744164] vhost-client 15380000.nvjpg: initialized
[ 1.747183] scrncapt: init (heads:3 wins:6 planes:4)
[ 1.747252] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.747257] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.747282] tegradccommon 15200000.dc_common: dma mapping done
[ 1.754709] ds90ub947_probe: entered
[ 1.754780] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor
[ 1.754803] generic_infoframe_type: 0x87
[ 1.754844] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.754886] tegradc 15200000.nvdisplay: Display dc.ffffff800a8d0000 registered with id=0
[ 1.759979] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.759987] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.759995] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.760763] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.760768] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.765612] tegradc 15200000.nvdisplay: probed
[ 1.781475] tegradc 15200000.nvdisplay: fb registered
[ 1.783533] gpio tegra-gpio wake19 for gpio=120(P:0)
[ 1.783867] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/dsi
[ 1.787031] ds90ub947-q1 6-000c: initializing registers failed
[ 1.787037] ds90ub947_probe: returning -5
[ 1.787099] ds90ub947-q1: probe of 6-000c failed with error -5
[ 1.788581] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.788942] kfuse 3830000.kfuse: initialized
[ 1.789515] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.795475] console [ttyS0] disabled
[ 1.799818] 3110000.serial: ttyS0 at MMIO 0x3110000 (irq = 44, base_baud = 25500000) is a Tegra
[ 1.799841] tegradc 15210000.nvdisplay: No hpd-gpio in DT
[ 1.799890] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.799910] tegradc 15210000.nvdisplay: Display dc.ffffff800abb0000 registered with id=1
[ 1.800104] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.800109] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.802740] tegradc 15210000.nvdisplay: DSI: HS clock rate is 445500
[ 1.804327] tegradc 15210000.nvdisplay: probed
[ 1.989409] tegradc 15210000.nvdisplay: fb registered
[ 1.991218] console [ttyS0] enabled
[ 1.991284] tegradc 15200000.nvdisplay: hdmi: plugged
[ 1.992509] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.992655] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.992777] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 2.008635] bootconsole [uart8250] disabled
[ 2.014273] tegra_profiler: Branch: Dev
[ 2.015672] tegra_profiler: Version: 1.121
[ 2.017131] tegra_profiler: Samples version: 42
[ 2.018824] tegra_profiler: IO version: 24
[ 2.020321] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.023708] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), pmuver: 0x1
[ 2.027579] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), pmuver: 0x1
[ 2.029839] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.032381] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.034714] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.037589] tegra_profiler: auth: init
[ 2.039440] THERMAL EST: found 2 subdevs
[ 2.040855] THERMAL EST num_resources: 0
[ 2.042297] [THERMAL EST subdev 0]
[ 2.043488] [THERMAL EST subdev 1]
[ 2.044890] thermal thermal_zone9: Registering thermal zone thermal_zone9 for type thermal-fan-est
[ 2.049445] THERMAL EST: thz register success.
[ 2.092525] THERMAL EST: end of probe, return err: 0
[ 2.094998] libphy: Fixed MDIO Bus: probed
[ 2.096424] tun: Universal TUN/TAP device driver, 1.6
[ 2.098061] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.100277] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.102153] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.104022] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.106216] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.108711] PPP generic driver version 2.4.2
[ 2.110554] PPP BSD Compression module registered
[ 2.112012] PPP Deflate Compression module registered
[ 2.112843] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 9c f1
[ 2.112900] libphy: dwc_phy: probed
[ 2.116731] PPP MPPE Compression module registered
[ 2.118263] NET: Registered protocol family 24
[ 2.119685] usbcore: registered new interface driver asix
[ 2.121424] usbcore: registered new interface driver ax88179_178a
[ 2.123329] usbcore: registered new interface driver cdc_ether
[ 2.125180] usbcore: registered new interface driver smsc95xx
[ 2.127037] usbcore: registered new interface driver net1080
[ 2.128815] usbcore: registered new interface driver cdc_subset
[ 2.130715] usbcore: registered new interface driver zaurus
[ 2.132481] usbcore: registered new interface driver cdc_ncm
[ 2.140066] tegra-xusb 3530000.xhci: USB2 port 2 has OTG_CAP
[ 2.141955] tegra-xusb 3530000.xhci: USB3 port 0 has OTG_CAP
[ 2.145595] Could not get extcon-dev /xhci@3530000:id(0)
[ 2.149085] usbcore: registered new interface driver usb-storage
[ 2.151460] mousedev: PS/2 mouse device common for all mice
[ 2.153364] usbcore: registered new interface driver xpad
[ 2.155521] i2c /dev entries driver
[ 2.157884] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 2.160887] isc-mgr isc-mgr.1: isc_mg_probeing…
[ 2.257790] sn65dsi85_dsi2lvds: PLL not locked
[ 2.282473] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[ 2.282496] generic_infoframe_type: 0x87
[ 2.282536] tegradc 15220000.nvdisplay: DT parsed successfully
[ 2.282560] tegradc 15220000.nvdisplay: Display dc.ffffff800af90000 registered with id=2
[ 2.282767] tegradc 15220000.nvdisplay: vblank syncpt # 14 for dc 2
[ 2.282772] tegradc 15220000.nvdisplay: vpulse3 syncpt # 15 for dc 2
[ 2.284819] tegradc 15220000.nvdisplay: hdmi: board prod-setting covers partial!
[ 2.286779] tegradc 15220000.nvdisplay: probed
[ 2.315152] tegradc 15220000.nvdisplay: fb registered
[ 2.315283] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 2.315547] isc-pwm isc_pwm_gen: isc_pwm_probeing…
[ 2.315599] isc-pwm isc_pwm_gen: isc_pwm_probe success to get PWM
[ 2.315663] usbcore: registered new interface driver uvcvideo
[ 2.315665] USB Video Class driver (1.1.1)
[ 2.315956] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 2.316203] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.316207] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.316459] FAN dev name: pwm-fan
[ 2.316536] FAN:gpio request success.
[ 2.316605] pwm_fan_driver pwm-fan: cap state:5, cap pwm:256
[ 2.316749] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.329426] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 2.329601] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.329638] pwm_fan_driver pwm-fan: tach period: 400
[ 2.330170] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=1400, rru=20, rrd=20, state:2
[ 2.330174] pwm_fan_driver pwm-fan: index 1: pwm=102, rpm=2300, rru=20, rrd=20, state:2
[ 2.330177] pwm_fan_driver pwm-fan: index 2: pwm=154, rpm=3700, rru=10, rrd=10, state:2
[ 2.330180] pwm_fan_driver pwm-fan: index 3: pwm=179, rpm=4500, rru=10, rrd=10, state:2
[ 2.330183] pwm_fan_driver pwm-fan: index 4: pwm=205, rpm=4900, rru=10, rrd=10, state:3
[ 2.330186] pwm_fan_driver pwm-fan: index 5: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 2.330189] pwm_fan_driver pwm-fan: index 6: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 2.330191] pwm_fan_driver pwm-fan: index 7: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 2.330194] pwm_fan_driver pwm-fan: index 8: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 2.33017] pwm_fan_driver pwm-fan: index 9: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 2.330898] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 2.333892] trusty-virtio trusty:virtio: initializing
[ 2.334178] trusty_ipc virtio0: vring0: va¶ ffffffc1cdce6000(0) qsz 32 notifyid 1
[ 2.334203] trusty_ipc virtio0: vring1: va¶ ffffffc1cdcf0000(0) qsz 32 notifyid 2
[ 2.334901] trusty-virtio trusty:virtio: initializing done
[ 2.334921] trusty_ipc virtio0: is online
[ 2.335202] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 2.335459] device-mapper: uevent: version 1.0.3
[ 2.335726] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.335999] tegra18x-cpufreq: Using hv path
[ 2.338159] cpufreq: platform driver Initialization: pass
[ 2.338437] sdhci: Secure Digital Host Controller Interface driver
[ 2.338439] sdhci: Copyright(c) Pierre Ossman
[ 2.338441] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.338635] sdhci-tegra 3460000.sdhci: runtime pm disabled
[ 2.339132] tegra_hv_vse vse@15810000: Virtual SE Stream ID: 72
[ 2.339136] tegra_hv_vse vse@15810000: Virtual SE channel number: 76
[ 2.340017] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.340631] tegra_hv_vse vse@15820000: Virtual SE Stream ID: 72
[ 2.347126] tegra_hv_vse vse@15830000: Virtual SE Stream ID: 72
[ 2.347565] tegra_hv_vse vse@15840000: Virtual SE Stream ID: 72
[ 2.349509] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.350220] usbcore: registered new interface driver usbhid
[ 2.350222] usbhid: USB HID core driver
[ 2.352466] tegra186-cam-rtcpu 2993000.rtcpu: Trace buffer configured at IOVA=0xbff80000
[ 2.352503] tegra186-cam-rtcpu 2993000.rtcpu: Coverage buffer configured at IOVA=0xbff78000
[ 2.379456] tegra186-cam-rtcpu 2993000.rtcpu: IOVM setup error: 130
[ 2.379469] tegra186-cam-rtcpu 2993000.rtcpu: RTCPU coverage: IOVM setup error : 4294967291
[ 2.379471] tegra186-cam-rtcpu 2993000.rtcpu: (expected if RTCPU was not built with coverage enabled)
[ 2.379475] tegra186-cam-rtcpu 2993000.rtcpu: coverage boot sync status: -5
[ 2.379705] tegra-ivc ivc-2993000.rtcpu: region 0: iova=0xbff60000-0xbff6d0ff size=53504
[ 2.379959] tegra-ivc ivc-2993000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.380000] tegra-ivc-cdev ivc-2993000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.38016] tegra-ivc ivc-2993000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.381386] tegra-ivc ivc-2993000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5a00-0x6e80 TX[16x320]=0x6e80-0x8300
[ 2.381441] tegra-ivc ivc-2993000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8300-0x8780 TX[16x64]=0x8780-0x8c00
[ 2.381484] tegra-ivc ivc-2993000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8c00-0x8e00 TX[1x384]=0x8e00-0x9000
[ 2.381515] tegra-ivc-cdev ivc-2993000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.381625] tegra-ivc ivc-2993000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9000-0xb080 TX[1x8192]=0xb080-0xd100
[ 2.382040] tegra186-cam-rtcpu 2993000.rtcpu: using cam RTCPU IRQ (426)
[ 2.382043] tegra186-cam-rtcpu 2993000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.383127] tegra186-cam-rtcpu 2993000.rtcpu: firmware version cpu=ape cmd=5 sha1=452963755b71a387ec2b19eb054b556179399f69
[ 2.383793] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.383892] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.384006] tegra18x_mce_write_uncore_mca: failed (ret=-1)
[ 2.384039] tegra18x_mce_write_uncore_mca: failed (ret=-1)
[ 2.384245] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 2.384296] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.385118] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.385352] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.385541] tegra18x_mce_write_uncore_perfmon: failed (ret=-1)
[ 2.385554] perfmon status error: 4294967295
[ 2.385555] ARI CMD:1 REG:6 CTR:0 Data:2
[ 2.385614] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.385645] Denver: backdoor interface is NOT available.
[ 2.385672] denver_knobs_init:MTS_VERSION:40418221
[ 2.390623] tegra_hv_pm_ctl tegra_hv_pm_ctl: tegra_hv_pm_ctl_probe: Probed
[ 2.391386] nvpmodel: initialized successfully
[ 2.391562] GACT probability NOT on
[ 2.391569] Mirror/redirect action on
[ 2.391576] 32 classifier
[ 2.391577] Actions configured
[ 2.391582] Netfilter messages via NETLINK v0.30.
[ 2.392167] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 2.392309] ctnetlink v0.93: registering with nfnetlink.
[ 2.393404] xt_time: kernel timezone is -0000
[ 2.393435] IPVS: Registered protocols ()
[ 2.393502] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.393591] IPVS: Creating netns size=1744 id=0
[ 2.394177] IPVS: ipvs loaded.
[ 2.394243] gre: GRE over IPv4 demultiplexor driver
[ 2.394702] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.394815] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 2.394959] Initializing XFRM netlink socket
[ 2.395441] NET: Registered protocol family 10
[ 2.396350] mip6: Mobile IPv6
[ 2.396421] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.397475] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.398001] ip6_gre: GRE over IPv6 tunneling driver
[ 2.398230] NET: Registered protocol family 17
[ 2.398242] NET: Registered protocol family 15
[ 2.398286] 8021q: 802.1Q VLAN Support v1.8
[ 2.398319] Key type dns_resolver registered
[ 2.398524] Registered cp15_barrier emulation handler
[ 2.398587] Registered setend emulation handler
[ 2.400200] registered taskstats version 1
[ 2.403021] isp 15600000.isp: initialized
[ 2.941180] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 2.941466] tegradc 15220000.nvdisplay: hdmi: keeping hotplug irq disabled
[ 2.946429] tegradc 15220000.nvdisplay: hdmi: plugged
[ 2.949559] nvcsi 150c0000.nvcsi: initialized
[ 2.955308] mmc0: hw tuning done …
[ 2.956407] ======= mmc0: Tuning windows =======
[ 2.956749] tegra-xusb 3530000.xhci: USB2 port 2 has OTG_CAP
[ 2.956753] tegra-xusb 3530000.xhci: USB3 port 0 has OTG_CAP
[ 2.957077] tegra-vi4 15700000.vi: initialized
[ 2.958975] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 2.959726] isc-mgr isc-mgr.0: isc_mgr_probe: success to get PWM
[ 2.961404] tegra-xusb 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 2.961421] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 2.961434] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number
[ 2.962243] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 2.962298] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 2.962388] isc-mgr isc-mgr.1: isc_mgr_probe: success to get PWM
[ 2.962614] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 2.962923] tegra-xusb 3530000.xhci: irq 73, io mem 0x03530000
[ 2.963056] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.963059] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.963061] usb usb1: Product: xHCI Host Controller
[ 2.963064] usb usb1: Manufacturer: Linux 4.9.80-rt61-tegra xhci-hcd
[ 2.963066] usb usb1: SerialNumber: 3530000.xhci
[ 2.964992] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 2.965063] isc-mgr isc-mgr.2: isc_mgr_probe: success to get PWM
[ 2.971973] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.971978] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.973321] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.973325] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.974578] hub 1-0:1.0: USB hub found
[ 2.974604] hub 1-0:1.0: 4 ports detected
[ 2.974889] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 2.974897] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 2.975048] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.975052] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.975056] usb usb2: Product: xHCI Host Controller
[ 2.975058] usb usb2: Manufacturer: Linux 4.9.80-rt61-tegra xhci-hcd
[ 2.975061] usb usb2: SerialNumber: 3530000.xhci
[ 2.975768] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.975800] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.976710] hub 2-0:1.0: USB hub found
[ 2.976737] hub 2-0:1.0: 3 ports detected
[ 2.977257] bwmgr: missing cdev-type property
[ 2.977918] hvc_sysfs: log is availble
[ 2.978015] hvc_sysfs: pct is available
[ 2.978331] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.978334] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.979724] Wake76 for irq=199
[ 2.979725] Wake77 for irq=199
[ 2.979726] Wake78 for irq=199
[ 2.979727] Wake79 for irq=199
[ 2.979729] Wake80 for irq=199
[ 2.979730] Wake81 for irq=199
[ 2.979730] Wake82 for irq=199
[ 2.979820] vdd-usb2-5v: disabling
[ 2.980247] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.980250] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 2.981903] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 2.981906] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 3.304023] mmc0: tuning window[0]: 0xffffffff
[ 3.304032] mmc0: tuning window[1]: 0xffffe3ff
[ 3.304049] mmc0: tuning window[2]: 0xfc7fffff
[ 3.304056] mmc0: tuning window[3]: 0xffffffff
[ 3.304063] mmc0: tuning window[4]: 0xffffff87
[ 3.304070] mmc0: tuning window[5]: 0xfff8ffff
[ 3.304107] mmc0: tuning window[6]: 0xfffffff
[ 3.304111] mmc0: tuning window[7]: 0x7fffffff
[ 3.304114] sdhci: Tap value: 10 | Trim value: 5
[ 3.304115] ==================================
[ 3.304118] Vendor clock ctrl: 0x50ad069
[ 3.304120] Vendor SysSW ctrl: 0x38607002
[ 3.304138] Vendor Err interrupt status : 0x40000
[ 3.304140] Vendor Cap overrides: 0x1107
[ 3.304142] Vendor Misc ctrl: 0xfffd0081
[ 3.304144] Vendor Misc ctrl_1: 0x0
[ 3.304146] Vendor Misc ctrl_2: 0x20e00000
[ 3.304148] Vendor IO trim ctrl: 0x11
[ 3.304150] Vendor Tuning ctrl: 0x7c028017
[ 3.304152] SDMEM comp padctrl: 0x8000007
[ 3.304154] Autocal config: 0x20010505
[ 3.304156] Autocal status: 0xe0d0908
[ 3.311010] mmc0: new HS400 MMC card at address 0001
[ 3.317553] mmcblk0: mmc0:0001 064G32 59.3 GiB
[ 3.321832] mmcblk0rpmb: mmc0:0001 064G32 partition 3 4.00 MiB
[ 3.323647] mmcblk0: p1 p2 p3 p4
[ 3.324782] egra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 3.324786] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 3.473028] Freeing unused kernel memory: 5376K
[ 3.475058] btb inv war enabled
[ 3.475076] invalidate_btb: smc failed, err (0xffffffff)
[ 3.488095] INITRAMFS STARTS
Getting target_board from device-tree …
[ 3.629457] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
[ 3.630772] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
[ 3.671428] EXT4-fs (mmcblk0p3): recovery complete
[ 3.672497] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.733720] Trying chroot to /new_root
[ 3.735067] INITRAMFS END
[ 3.792761] systemd[1]: System time before build time, advancing clock.
[ 3.820061] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 3.826863] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 16.04 LTS!
[ 3.833459] systemd[1]: Set hostname to .
[ 3.994239] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.997883] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.005918] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.009527] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.014329] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.017597] systemd[1]: Reached target Encrypted Volumes.
[ OK ] Reached target Encrypted Volumes.
[ 4.020783] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on LVM2 metadata daemon socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Journal Socket.
Starting Set CPUs online service…
[ OK ] Started Braille Device Support.
Mounting POSIX Message Queue File System…
Starting nv-run-date.service…
Starting Remount Root and Kernel File Systems…
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Device-mapper event daemon FIFOs.
Starting Monitoring of LVM2 mirrors… dmeventd or progress polling…
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on LVM2 poll daemon socket.
Starting Create list of required st… nodes for the current kernel…
Mounting Debug File System…
[ OK ] Listening on udev Kernel Socket.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ OK ] Listening on Syslog Socket.
Starting Journal Service…
Starting Load Kernel Modules…
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Debug File System.
[ 4.183761] usbcore: registered new interface driver rndis_host
[ OK ] Started Set CPUs online service.
[ 4.206839] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 4.208093] tegra-tj-thermal tegra-tj: Tdiode_tegra driver not initialized… Deferring the probe
[ 4.248331] loop: module loaded
[ OK ] Started nv-run-date.service.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Create list of required sta…ce nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Journal Service.
[ OK ] Started LVM2 metadata daemon.
Mounting Configuration File System…
Starting Apply Kernel Variables…
Mounting FUSE Control File System…
Starting Create Static Device Nodes in /dev…
Starting Load/Save Random Seed…
Starting Flush Journal to Persistent Storage…
Starting udev Coldplug all Devices…
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Load/Save Random Seed.
Starting udev Kernel Device Manager…
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Monitoring of LVM2 mirrors,…ng dmeventd or progress polling.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Clean up any mess left by 0dns-up…
Starting LSB: AppArmor initialization…
Starting Create Volatile Files and Directories…
Starting Set console keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[FAILED] Failed to start Clean up any mess left by 0dns-up.
See ‘systemctl status dns-clean.service’ for details.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Set console keymap.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started LSB: AppArmor initialization.
Starting Update UTMP about System Boot/Shutdown…
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Reached target System Time Synchronized.
Starting Network Service…
Starting Raise network interfaces…
[ OK ] Started udev Coldplug all Devices.
[FAILED] Failed to start Network Service.
See ‘systemctl status systemd-networkd.service’ for details.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Stopped Network Service.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target System Initialization.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on GPS (Global Positioning System) Daemon Sockets.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
Starting Socket activation for snappy daemon.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started CUPS Scheduler.
[ OK ] Reached target Paths.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Login Service…
Starting System Logging Service…
[ OK ] Started Run anacron jobs.
Starting Modem Manager…
Starting Avahi mDNS/DNS-SD Stack…
Starting Board specific initialization…
Starting board specific init …
Starting LSB: automatic crash report generation…
[ OK ] Started GPS (Global Positioning System) Daemon.
Starting LSB: Speech Dispatcher…
[ OK ] Started mnand refresh daemon service.
[ OK ] Started Regular background program processing daemon.
Starting LSB: Set up cgroupfs mounts…
Starting Permit User Sessions…
[ OK ] Started D-Bus System Message Bus.
Starting oFono Mobile telephony stack…
[ INFO ] Network Manager is not active.
[DEPEND] Dependency failed for Network Manager Wait Online.
[ OK ] Started Hypervisor initiated Shutdown Service.
[ OK ] Started crash report submission daemon.
Starting Accounts Service…
Starting Restore /etc/resolv.conf i…re the ppp link was shut down…
Starting LSB: Set the CPU Frequency Scaling governor to “ondemand”…
[ OK ] Started Raise network interfaces.
[FAILED] Failed to start Login Service.
See ‘systemctl status systemd-logind.service’ for details.
[FAILED] Failed to start System Logging Service.
See ‘systemctl status rsyslog.service’ for details.
[FAILED] Failed to start Modem Manager.
See ‘systemctl status ModemManager.service’ for details.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
See ‘systemctl status avahi-daemon.service’ for details.
[FAILED] Failed to start Board specific initialization.
See ‘systemctl status nv_board_init.service’ for details.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started LSB: Speech Dispatcher.
[ OK ] Started LSB: Set up cgroupfs mounts…
[ OK ] Started Permit User Sessions.
[FAILED] Failed to start oFono Mobile telephony stack.
See ‘systemctl status ofono.service’ for details.
[FAILED] Failed to start Accounts Service.
See ‘systemctl status accounts-daemon.service’ for details.
[ OK ] Started Restore /etc/resolv.conf if…fore the ppp link was shut down.
[ OK ] Started LSB: Set the CPU Frequency Scaling governor to “ondemand”.
