i’d like to ask that since Physx provides the tank vehicle implmentation, why not give any tank sample.
one problem about tank has confused me for a long time, should i assign how much thrust value when in turn and drive state simutaneously?
if i use 0 for left and 1 for right, the tank will accelerate rapidly, even the speed exceeds the max speed which i set for drive state
if i use -1 for left and 1 for right, the tank will slow down for a little, but when i pressed the forward key, it will never get accelerated.
note: i know that when i just want to turn, i can set -1 for left thrust and 1 for right thrust, it works well, there’s no any problem about it, which confused me is that when i want to turn and drive the tank simutaneously, namely when “w” key and “a” key are both pressed, should i assign how much value to the five input variable: analogaccel, left thrust, right thrust, left brake, right brake.
i would very appreciate for your help! PhysX SDK 3.3.1
