and it looks quite interesting! Since programming under python is WAY easier than C…
is there any mayor drawback in using python?
I supposed that there would be a substantial efficiency lost, but they claim that there’s almost none. So maybe you lose flexibility? control over the hardware?
I would like to start programming, but being a mathematician rather than a programmer, this would help me a lot to concentrate on the algorithm rather than on its implementation…
Side note: If you know MATLAB, you can just install the Accelereyes Jacket program, which adds CUDA acceleration to MATLAB. I figured since you’re a mathematician, you probably have some experience with it…
I’m fairly sure that you can export/compile MATLAB programs to native code (i.e. an exe or DLL), and I do know that MATLAB exposes a COM server, so you can make calls to MATLAB from another program (e.g. to run the algorithm ‘behind the scenes’)
profquail is correct… you can invoke and run MATLAB code/scripts (including Jacket code/scripts) from external applications without having the user of the external application know anything about MATLAB (except for the fact that it must be installed on the machine). In fact, I recently implemented this for an open source visualization tool, Slicer3 (see http://www.na-mic.org/Wiki/index.php/Proje...rExampleModule).
But, in the end, we realize that many people will want to be able to put Jacket code directly into end products/applications. So we have as a priority on our roadmap the creation of an avenue for people to statically compile Jacket’ed CUDA code into an application.
