pycuda._driver.MemoryError: cuMemHostAlloc failed: out of memory YOLOv7
I converted ONNX to .engine by command
./trtexec --onnx=/opt/nvidia/deepstream/deepstream-6.2/sources/yolov7/YOLOv7_Chien/pretrained_models/yolov7.onnx --explicitBatch --saveEngine=/opt/nvidia/deepstream/deepstream-6.2/sources/yolov7/YOLOv7_Chien/pretrained_models/yolov7_fp32.engine --workspace=4096
And evaluate .engine model, a part of code as follow
        logger = trt.Logger(trt.Logger.WARNING)
        logger.min_severity = trt.Logger.Severity.ERROR
        runtime = trt.Runtime(logger)
        trt.init_libnvinfer_plugins(logger,'') # initialize TensorRT plugins
        with open(engine_path, "rb") as f:
            serialized_engine = f.read()
        engine = runtime.deserialize_cuda_engine(serialized_engine)
        self.imgsz = engine.get_binding_shape(0)[2:]  # get the read shape of model, in case user input it wrong
        self.context = engine.create_execution_context()
        self.inputs, self.outputs, self.bindings = [], [], []
        self.stream = cuda.Stream()
        for binding in engine:
            size = trt.volume(engine.get_binding_shape(binding))   #CHANGE
            dtype = trt.nptype(engine.get_binding_dtype(binding))
            print("ab", type(size), dtype)
            host_mem = cuda.pagelocked_empty(size, dtype)
            device_mem = cuda.mem_alloc(host_mem.nbytes)
            self.bindings.append(int(device_mem))
            if engine.binding_is_input(binding):
                self.inputs.append({'host': host_mem, 'device': device_mem})
            else:
                self.outputs.append({'host': host_mem, 'device': device_mem})
But I got error
Namespace(engine='../YOLOv7_Chien/pretrained_models/yolov7_fp32.engine', folder='val2017/')
  File "infer_trt_yolov7.py", line 44, in <module>
    pred = Predictor(engine_path=args.engine)
  File "infer_trt_yolov7.py", line 14, in __init__
    super(Predictor, self).__init__(engine_path)
  File "/opt/nvidia/deepstream/deepstream-6.2/sources/yolov7/YOLOv7_TensorRT_Evaluation/utils/utils.py", line 40, in __init__
My GPU has 11 GB ram, i think it’s sufficient to run evaluate .engine model. Please help me.
Please check the GPU memory available and make sure no other task is consuming the available resources.
This error can also happen if you pass a negative size in cuda.mem_alloc, could you please check.
Thank you.
