With this code I want to draw filled triangles:
import cv2
import numpy as np
import os
import time
import math
import pycuda.autoinit
import pycuda.driver as cuda
from pycuda.compiler import SourceModule
executions_per_frame = 10
pycuda_code = """
__device__ void set_pixel_3d(unsigned char *canvas, int* canvas_shape, float *z_buffer, int x, int y, float z, unsigned char *color) {
int index = y * canvas_shape[1] + x;
if (z > z_buffer[index]) {
z_buffer[index] = z;
for (int i = 0; i < canvas_shape[2]; ++i) {
canvas[index * canvas_shape[2] + i] = color[i];
// l/r - left/right
// l/u - lower/upper
__global__ void draw_triangle(unsigned char *canvas, int *canvas_shape, float *z_buffer, float *ll, float *rl, float *lu, float *ru, unsigned char *color, int height, int min_x, int min_y) {
int global_thread_x = threadIdx.x + blockIdx.x * blockDim.x;
int global_thread_y = threadIdx.y + blockIdx.y * blockDim.y;
float k1 = (float)global_thread_y / height;
int left_x = (int)(ll[0] + (lu[0] - ll[0]) * k1);
int right_x = (int)(rl[0] + (ru[0] - rl[0]) * k1);
float left_z = ll[2] + (lu[2] - ll[2]) * k1;
float right_z = rl[2] + (ru[2] - rl[2]) * k1;
int actual_x = min_x + global_thread_x;
if (left_x != right_x && left_x <= actual_x && actual_x <= right_x) {
int actual_y = min_y + global_thread_y;
float k2 = (float)(global_thread_x - (left_x - min_x)) / (right_x - left_x);
float actual_z = left_z + (right_z - left_z) * k2;
set_pixel_3d(canvas, canvas_shape, z_buffer, actual_x, actual_y, actual_z, color);
if __name__ == '__main__':
if (os.system("cl.exe")):
os.environ['PATH'] += ';' + r"C:\Program Files\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\Hostx64\x64"
raise RuntimeError("cl.exe still not found")
pycuda_src_module = SourceModule(pycuda_code, no_extern_c=True)
pycuda_draw_triangle = pycuda_src_module.get_function("_Z13draw_trianglePhPiPfS1_S1_S1_S1_S_iii")
time_start, frames_count, fps = time.time(), 0, 0
while True:
key = cv2.waitKeyEx(1)
if key == 27:
break
canvas_width, canvas_height = 1000, 800
canvas = np.zeros((canvas_height, canvas_width, 3), dtype=np.uint8)
z_buffer = np.zeros((canvas_height, canvas_width), dtype=np.float32)
fragment_width, fragment_height = 400, 300
color = [0, 0, 200]
block_side = 32
block_dim = (block_side, block_side, 1)
grid_dim = (math.ceil(fragment_width / block_side), math.ceil(fragment_height / block_side))
param_canvas = cuda.InOut(canvas) # unsigned char *canvas
param_canvas_shape = cuda.In(np.array(canvas.shape, dtype=np.int32)) # int *canvas_shape
param_z_buffer = cuda.InOut(z_buffer) # float *z_buffer
param_ll = cuda.In(np.array([100, 200, frames_count], dtype=np.float32)) # float *ll
param_rl = cuda.In(np.array([500, 200, frames_count], dtype=np.float32)) # float *rl
param_lu = cuda.In(np.array([400, 500, frames_count], dtype=np.float32)) # float *lu
param_ru = cuda.In(np.array([400, 500, frames_count], dtype=np.float32)) # float *ru
param_color = cuda.In(np.array(color, dtype=np.uint8)) # unsigned char *color
param_height = np.int32(fragment_height) # int height
param_min_x = np.int32(100) # int min_x
param_min_y = np.int32(200) # int min_y
for i in range(executions_per_frame):
pycuda_draw_triangle(param_canvas, param_canvas_shape,
param_z_buffer, param_ll, param_rl, param_lu, param_ru,
param_color, param_height, param_min_x, param_min_y,
block=block_dim, grid=grid_dim)
frames_count += 1
fps = frames_count / (time.time() - time_start)
cv2.putText(canvas, "fps={:0.2f}".format(fps), (5, 20), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (255, 255, 255))
cv2.imshow('Scene', canvas)
cv2.destroyAllWindows()
With executions_per_frame=1 (for 1 iteration C function will be called 1 time) I got ~100 fps, with executions_per_frame=10 - ~30 fps. It doesn’t look as productive as it could be. What did I miss?
Also, does this have benefit in that particular task?
block_side = 32
pycuda_draw_triangle(..., block=block_dim, grid=grid_dim)
Or it can be just
pycuda_draw_triangle(..., block=(1, 1, 1), grid=(fragment_width, fragment_height))
Python 3.6.9, CUDA 10.0, RTX 2060
