Hello
I am a real beginner in CUDA (I just installed PyCuda, that’s all).
Consider this code for example (the content is not really important)
#!python
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Multiplies two square matrices together using a *single* block of threads and
global memory only. Each thread computes one element of the resulting matrix.
import numpy as np
from pycuda import driver, compiler, gpuarray, tools
# -- initialize the device
import pycuda.autoinit
kernel_code_template = """
__global__ void MatrixMulKernel(float *a, float *b, float *c)
// 2D Thread ID (assuming that only *one* block will be executed)
int tx = threadIdx.x;
int ty = threadIdx.y;
// Pvalue is used to store the element of the matrix
// that is computed by the thread
float Pvalue = 0;
// Each thread loads one row of M and one column of N,
// to produce one element of P.
for (int k = 0; k < %(MATRIX_SIZE)s; ++k) {
float Aelement = a[ty * %(MATRIX_SIZE)s + k];
float Belement = b[k * %(MATRIX_SIZE)s + tx];
Pvalue += Aelement * Belement;
// Write the matrix to device memory;
// each thread writes one element
c[ty * %(MATRIX_SIZE)s + tx] = Pvalue;
# define the (square) matrix size
# note that we'll only use *one* block of threads here
# as a consequence this number (squared) can't exceed max_threads,
# see http://documen.tician.de/pycuda/util.html#pycuda.tools.DeviceData
# for more information on how to get this number for your device
MATRIX_SIZE = 2
# create two random square matrices
a_cpu = np.random.randn(MATRIX_SIZE, MATRIX_SIZE).astype(np.float32)
b_cpu = np.random.randn(MATRIX_SIZE, MATRIX_SIZE).astype(np.float32)
# compute reference on the CPU to verify GPU computation
c_cpu = np.dot(a_cpu, b_cpu)
# transfer host (CPU) memory to device (GPU) memory
a_gpu = gpuarray.to_gpu(a_cpu)
b_gpu = gpuarray.to_gpu(b_cpu)
# create empty gpu array for the result (C = A * B)
c_gpu = gpuarray.empty((MATRIX_SIZE, MATRIX_SIZE), np.float32)
# get the kernel code from the template
# by specifying the constant MATRIX_SIZE
kernel_code = kernel_code_template % {
'MATRIX_SIZE': MATRIX_SIZE
# compile the kernel code
mod = compiler.SourceModule(kernel_code)
# get the kernel function from the compiled module
matrixmul = mod.get_function("MatrixMulKernel")
# call the kernel on the card
matrixmul(
# inputs
a_gpu, b_gpu,
# output
c_gpu,
# (only one) block of MATRIX_SIZE x MATRIX_SIZE threads
block = (MATRIX_SIZE, MATRIX_SIZE, 1),
# print the results
print("-" * 80)
print("Matrix A (GPU):")
print(a_gpu.get())
print("-" * 80)
print("Matrix B (GPU):")
print(b_gpu.get())
print("-" * 80)
print("Matrix C (GPU):")
print(c_gpu.get())
print("-" * 80)
print("CPU-GPU difference:")
print(c_cpu - c_gpu.get())
np.allclose(c_cpu, c_gpu.get())
This code works well. But imagine I change c[ty * %(MATRIX_SIZE)s + tx] in the function to c, then the code won’t compile. But python will only tell me :
“CompileError: nvcc compilation of C:\Users\Me\AppData\Local\Temp\tmpfhvth9of\kernel.cu failed”
In other words, the compiler is not able to tell me what the exact error is, it just tells me that an error occured somewhere.
Can Python have access to the part of the CUDA code that failed or is it impossible ?
If so, is the only way to debug a CUDA code to write it in C++ ?
Thank you.
