Ubuntu 16.04, Jetson TX2.
Host: Ubuntu 16.04
cuda: 9.2
Python: python3.5
I have installed Tensor RT, Cuda 9.2, and tensor flow. I installed pycuda as per instructions in Installing PyCUDA on Linux - Andreas Klöckner's Former Wiki . The following is the issue:
- I have already installed numpy using pip3 command
- When I typed the command su -c “python distribute_setup.py” I get an error stating there is no file in that name.
Alternatively, I tried running the ‘setup.py.’ It started throwing error saying it cannot find ‘numpy’ module.
Note: I have created a CUDA_ROOT ajavascript:void(0);nd PATH variable to cuda 9.2’s root directory. In my case, it is /usr/local/cuda-9.2/bin.
Any help to solve this problem will be highly appreciated! Thanks
